preseting eeprom
Mattr0
preseting eeprom
PostPosted: Tue Mar 29, 2005 7:33 am     Reply with quote
Is there a way to preprogram a memory location at the time of programming?
PostPosted: Tue Mar 29, 2005 8:44 am     Reply with quote
Yes.
#ROM
You need to look in the programming spec for the particular chip family involved to find where the EEPROM 'appears', as far as the programmer is concerned, but for the 18F family, which has it at 0xF00000, you can put a block of data into the EEPROM, with:
#ROM 0xF00000 = { 0x00AA,
   0x3689,0x00E0,
   0x3688,0x00C0
This writes 16bit values. If you want to address the ROM as bytes, you can add 'int8' to the declaration.
On the 16 chips, the ROM defaults to 8bit mapping.
theMagni
PostPosted: Tue Mar 29, 2005 6:26 pm     Reply with quote
I do it all the time to load default values. Here's the relevant code for a 16F88. Note that the EEPROM starts at location 0x2100, so I have to add that offset to each location. (It seems to be the same for the 16F family, but don't quote me.) I don't know why CCS didn't automatically put the offset for each device into the #ROM command, but I'm sure that there's a good reason.
For more details, consult the manual for #ROM.
#ROM 0x2100 = { 0x00, 0x00 }
#ROM 0x2108 = { 0x1D }  //ID number
#ROM 0x2110 = { 0x01 }  //delay between fixes
#ROM 0x2118 = { 0x01 }  //always get a fix
#ROM 0x2120 = { 0x00 }  //fix offset
#ROM 0x2128 = { 0x00 }  //VHF_START_TIME
#ROM 0x2130 = { 0x00 }  //VHF_STOP_TIME
#ROM 0x2138 = { 0x19 }  //GPS_TRANSMIT_TIME
#ROM 0x2140 = { 0xB0 }  //PULSE_RATE
#ROM 0x2148 = { 0xB1 }  //MORT_PULSE_RATE
#ROM 0x2150 = { 0x00 }  //TRACK_MOVEMENT
#ROM 0x2158 = { 0x01 }  //USE_PTT
#ROM 0x2160 = { 0x00 }  //USE_SW
In the 90's, I promised myself I'd never use a so-called "smiley icon". I hate what I've become. ;)
Mark
PostPosted: Tue Mar 29, 2005 6:58 pm     Reply with quote
You can use the #ROM directive to store data in the flash area too, can't you? Wouldn't this be a good reason not to add an offset. Besides, it would be one more thing that could change between chips and one more place to introduce and error!
PostPosted: Wed Mar 30, 2005 2:52 am     Reply with quote
Yes. The #ROM directive is important for doing other things in the program memory, so a 'built in' offset would be a pain.
However I'd suggest something like this as a good way of being 'user friendy' for the EEPROM.
#if defined (__PCH__)
#define EE_BASE (0xF00000)
#else
#define EE_BASE (0x2100)
#define EE_BYTE(x,y) #ROM int8 EE_BASE+x = { y }
Then to put '4' into the tenth EEPROM address (remembering they start at '0'), would just need:
EE_BYTE(9,4)
The nice thing about this, is it automatically handles the fact that the 18 chips store 16bit values, and the 16 chips store 8bit values, addressing both the same way, and allowing the code to be portble between the families. :-)
