ADC reading LOW
astus
ADC reading LOW
PostPosted: Tue Mar 29, 2005 9:56 am     Reply with quote
I am having a problem with a pic16f819 reading the ADC. The value is allwways far too low. This is using either the vref tied to 5v and gnd or all analog with the internal Vdd and vss ref. The code is below
void main () {
long int volts; //Stores current channel voltage in use
long int max_volt = 0;
int state = MEASURE;
short int max_flag = FALSE;
long int timer;
short int led_flag = FALSE;
int16 test;
setup_oscillator( OSC_1MHZ );
setup_adc_ports( AN0_AN1_AN4_VREF_VREF );
setup_adc( ADC_CLOCK_INTERNAL );
do {
set_adc_channel( 0 ); //Set ADC Channel
// delay_us( ADC_SETTLE ); //Wait for ADC Channel to Settle
test = read_adc();
} while(TRUE);
The input has a 1uf and 100 nf cap and is is a voltage divison down and clamped with a 5v1 zener. A typical voltage reading at the adc input is 4.2 volts and the icd debugger shows the value read out to be 218 steps of 218*5/1024 = 1.06V Any hints? Crying or Very sad
PostPosted: Tue Mar 29, 2005 10:07 am     Reply with quote
The ratio of 4.2v to 1.06v should be a real big clue. It's about 4:1.
Anytime you see an error in the computer world that is a power of 2,
you should immediately start looking at a bit-shift problem.
Look in the CCS manual at read_adc() function, especially with
respect to the #device adc statement.
astus
PostPosted: Tue Mar 29, 2005 4:59 pm     Reply with quote
YEah I found the ADC=10 , I also passed the read_adc() to a long, the adc is reading correclty but the complier is not taking the upper bits from the adc high register. I also tried using the #BYTE command to specifiy the high and low of ADC then tried using the make16(). The compilier seems to ignore the make16() command completely?
IT seems that long integers are not being passed proplery? anybody got a clue?
By the way I'm using the latest pcm compilier, got it last week.
Adam
PostPosted: Tue Mar 29, 2005 5:15 pm     Reply with quote
Here is the code from PCM vs. 3.222. It looks OK to me.
0000                00258 .................... result = read_adc();
000C 1283       00259 BCF    03.5   // Bank 0
000D 151F       00260 BSF    1F.2   // Set Go bit = 1
000E 191F       00261 BTFSC  1F.2   // Wait until conversion is done
000F 280E       00262 GOTO   00E
0010 1683       00263 BSF    03.5   // Bank 1
0011 081E       00264 MOVF   1E,W   // Read ADRESL  (0x9E)
0012 1283       00265 BCF    03.5   // Bank 0
0013 00A1       00266 MOVWF  21     // Put ADRESL into LSB of result
0014 081E       00267 MOVF   1E,W   // Read ADRESH
0015 00A2       00268 MOVWF  22     // Put ADRESH into MSB of result
I wonder if you're doing the #device adc=10 correctly. The #device
line should be placed immediately below the #include line for the PIC.
Example:
#include <16F819.H>
#device adc=10
future
PostPosted: Tue Mar 29, 2005 6:40 pm     Reply with quote
5v1 zeners will start to clamp below 5.1volts, remove them and you will see the correct values.
Mark
PostPosted: Tue Mar 29, 2005 7:02 pm     Reply with quote
Not all zeners work the same. We had some manufacturers that we had to put on the "blacklist" because they let too much current before they should have. This cause too big a voltage drop and we couldn't obtain high enough readings.
future
PostPosted: Tue Mar 29, 2005 7:43 pm     Reply with quote
I was never able to use 5v1 zeners successfully and ended removing them from the board.
Protection is done by the PIC itself, with a 1k current limit resistor and a 100nf cap to ground.
astus
PostPosted: Wed Mar 30, 2005 3:37 am     Reply with quote
Thanks guys, The adc is actually reading correctly as shown in the special function registers. It is the compilier that seems to confusing the longs and ints. I will move the #device command under the include and see if that helps. Once again thanks for your support.
Regards
Adam
JohnKennedy
PostPosted: Wed Mar 30, 2005 3:46 am     Reply with quote
Hi you need to include the following in the header file or it will default to working in 8 bit mode
#DEVICE   *=16 ADC=10
I use this using the 16F818 with no problems
HTH
JFK
