webbone
Joined: 20 Sep 2004 Posts: 14 Location: Sacramento, CA
printf() problem displaying float value without decimal plac |
Posted: Mon Mar 28, 2005 10:16 pm |
I am trying to get printf() to output a 2 digit display value from a float value and have not had success thus far getting it to behave. The float variable has a value between 0 and 70 and I only want to display ' 0', '70', '35' and similar such concepts.
Normally I would use something like this if I wanted ' 0.1', '70.0', '35.4':
Code: | printf ("%04.1f",fVariable); |
Thus I would assume I could use this for my desired goal:
Code: | printf ("%02f",fVariable); |
No such luck. Other combinations including "%2.0f", "%02.0f", "%3.0f" do no yield the desired effect either.
Any suggestions? I can always convert to an Int and then display but I would think that the native printf() function SHOULD just be able to do this properly.
For reference I'm working on an 18F8720 and I'm on version 3.214 of the compiler. |
Posted: Tue Mar 29, 2005 2:24 am |
%3.0f, should have given the required effect. There do seem to be some compiler 'issues', with the way the conversion arithmetic is done, leading to tiny errors, but I have just tried it, and %3.0f, for a float 'val', counting from 1 to 10, gives 1,2,3,4,5,6,7,8,9,10 on 3.221.
There is though a leading space, since this is the default for numbers. It may be that you need the %-3.0f format, which moves the numbers tight to the left of the output field, rather than giving this space, which unfortunately, CCS don't support in their version of printf...
You can simulate the effect, by using sprintf to a string buffer, and then printf to output the result from one character right. So:
int8 b[6];
sprintf(b,"%3.0f",val);
printf("%s",b+1);
