Just tried to recompile some old code with Version 3.221 of compiler for the PIC16F767.
I used read_program_eeprom() for some stored data. I now get an error undefined identifier?
This worked with version 3.216.
Has CCS removed this command?.
I checked the data sheet for the PIC16f767 and a read program memory is allowed.
Has anyone encountered this problem.
Posted: Mon Mar 28, 2005 2:06 pm
Read the 'readme.txt' with the compiler version. To write without having to erase first, you should be using 'write_program_memory'. However the eeprom version certainly should exist.
Posted: Mon Mar 28, 2005 2:22 pm
I just tested it. Results:
PCM 3.188 -- compiles OK
PCM 3.221 -- undefined identifier
PCM 3.222 -- compiles OK
Conclusion: They broke it in 3.221, and fixed it in 3.222.
If possible, download 3.222. If your download rights ran out
and you don't have the old version, then you could email CCS
and make the case that they should let you download 3.222
so that you have a working version again.
