Predator_MF
PIC18F452 Bootloader-How to PLACE "#USE RS232" in |
Posted: Sat Mar 26, 2005 3:13 am |
Hi everybody
So, this is my HUGE problem:
I've imlemented bootloader into my PIC. It's working fine until reaching the 10 lines generated by "#use RS232...". As these 10 lines are placed exactly at the beginnig of the main() function and the bootloader use them for recieving/sending data, when they are erased by write_program_memory function, the loader stops there!
My question is how can I place "#use RS232" whereever I want?
I've tryed with #ORG or placing it into bootloader section, but no results...
Thanks.
Posted: Sat Mar 26, 2005 3:48 am |
To move the core parts of the program, use #build. A search for this term on the forum, will show you how to use this with a bootloader. #org, allows you to put blocks of code at specific locations 'inside' the area being used, but the compiler still requires it's own code to go at the bottom of memory. #build allows you to change this.
Predator_MF
Posted: Sat Mar 26, 2005 4:00 am |
As I understand #build shows the compilator where RESET and INTERRUPT vectors are placed. How exactly this would help me?
Code: | #use rs232(baud=500000,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,enable=PIN_D0)
0E6E: BCF F95.0
0E70: BSF F8C.0
0E72: BTFSS F9E.4
0E74: BRA 0E72
0E76: MOVLB 5
0E78: MOVFF 51C,FAD
0E7C: NOP
0E7E: BCF F95.0
0E80: BSF F8C.0
0E82: BTFSS FAC.1
0E84: BRA 0E82
0E86: BCF F95.0
0E88: BCF F8C.0
0E8A: MOVLB 0
0E8C: RETLW 00
0E8E: NOP(FFFF) |
I want this code to be placed in the bootloader area! |
Posted: Sat Mar 26, 2005 4:23 am |
You should be building two seperate programs. The first is your bootloader, and presumably needs to have it's entry vector at the bottom of memory as 'normal'. The second is the program to load with your bootloader, which needs to avoid the bottom of memory area. This is then built using #build, to avoid it overwriting the bootloader, and the jump vectors placed by the bootloader. A program 'built' with the build option, with it's entry point moved up, places the standard routines like the timing code for RS232, similarly relocated upwards as well.
Predator_MF
Posted: Sat Mar 26, 2005 5:51 am |
How hard this could be!!! However I try, the #USE RS232 code is always placed at some location that compilator have chosen. I've tryed a stand-alone code with #build (RESET = 0x7AFF) and the #USE RS232 is placed at 01C40...WHY? |
Posted: Sat Mar 26, 2005 6:52 am |
if you use the #org with DEFAULT option and a #use rs232 inside the area defined by #org, ALL code are placed inside this area. you can place another #use rs232 in the main program. i use this for my LOADER, not BOOTLOADER (a loader function what update the program under main program control.. ) . in my case i receive the new program code from a GSM modem, store it into an external eeprom, and then i copy this into the CPU, MANTAINING the control of the operation ...
If is this what you want, here is the code what i use:
#org 0x7d0a,0x7fff AUTO=0 DEFAULT
void loader1(void)
il codice e' scritto in eeprom a partire dal "blocco" E000 a blocco FFFF (ultimi 32K della eeprom ext)
viene copiato su eeprom_pic (esclusa la zona tra 0x00 0x1ff (bootloader) e la zona 0x7d00 0x7fff (loader).
NON AGGIUNGERE NULLA CHE FACCIA RIFERIMENTO A PEZZI DI CODICE FUORI DA QUESTO INTERVALLO
// nel programma ci sono piu' #use i2c .. questo e' usato SOLO dal loader ..
#use i2c(master,fast,sda=pin_c4, scl=pin_c3, restart_wdt) //
int16 indirizzo;
int8 n;
restart_wdt();
disable_interrupts(global);
disable_interrupts(int_rda);
disable_interrupts(int_rtcc);
disable_interrupts(int_timer1);
disable_interrupts(int_ext);
restart_wdt();
i2c_start();
i2c_write(0b10101110); // scrive l'indirizzo
i2c_write(0x02); // parte superiore dell'indirizzo vero di inizio blocco dati (primo byte di banco 1 eeprom 03)
i2c_write(0x00); // parte inferiore
i2c_start();
i2c_write(0b10101111); // adesso legge
for (indirizzo=0x0200;indirizzo<0x7d00;indirizzo=indirizzo+64)
for(n=0;n<64;n++){restart_wdt();g_stg[n]=i2c_read();}
WRITE_PROGRAM_MEMORY((int32)indirizzo, g_stg, 64);
n = i2c_read(0); // fittizzio, solo per NON dare ack alla eeprom ( -> ..(0) ) prima dello STOP
i2c_stop();
reset_cpu();
#org default
enjoy .
Mauro ik1wvq |
Posted: Sat Mar 26, 2005 6:56 am |
Look at bootload.c, and bootloader.c, together with the include files. Basically you cannot reserve the base area, unless you have moved the vectors (obvious really), but you still have to do the reservation seperately. Also it is vital that the reservations are made before the clock definition line, and the RS232 definiton line (if you are using software RS232), otherwise both will still stick code into the unreserved areas.
Predator_MF
Posted: Sat Mar 26, 2005 7:01 am |
Mauro wrote: | a loader function what update the program under main program control.. |
This is exactly what I'm trying to do! Thanks alot... |
jds-pic
Posted: Mon Mar 28, 2005 9:02 am |
Predator_MF wrote: | Mauro wrote: | a loader function what update the program under main program control.. |
next, you will need to read this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=20282
jds-pic |
