| 1-wire |
Posted: Wed Mar 23, 2005 4:08 pm |
Hi !
I'd like to use the DS2480 or DS2490 or DS1481 1-Wire for a project.
Could anybody provide me some C code?
Many thanks. |
SherpaDoug
Posted: Thu Mar 24, 2005 12:18 pm |
Look at EX_TOUCH.C in the examples file. It shows how to use Dallas one-touch devices in general. You will have to write your own drivers for specific chips. _________________ The search for better is endless. Instead simply find very good and get the job done. |
global
| 1-wire DS2411 |
Posted: Fri Mar 25, 2005 2:27 am |
i have this program which uses 1-wire, and it gives :
| Quote: | | DS2411_DATA = aab7dfaeb6af5555 |
In the datasheet, it indicates that if the CRC matches the last 8 bits of the registration number, the transmission is error free.
I think here it is not good, could someone tell me what is wrong in there ?
#include <header.h>
****************************** Functions prototypes ****************************
void main (void);
void init(void);
int8 Reset(void);
void Write1(void);
void Write0(void);
int8 Readx(void);
void WriteByte(int Data);
int8 ReadByte(void);
byte ROM_BUFFER[8]; //ROM Code Buffer
************************************** main ************************************
init();
byte i;
if(!Reset())
WriteByte(0x33);
for(i = 0; i < 8; i++)
ROM_BUFFER[i] = ReadByte();
printf("\nDS2411_DATA = %x%x%x%x%x%x%x%x",ROM_BUFFER[7], ROM_BUFFER[6],ROM_BUFFER[5],
ROM_BUFFER[4], ROM_BUFFER[3], ROM_BUFFER[2], ROM_BUFFER[1], ROM_BUFFER[0]);
//printf("\nCRC_DATA = %x", ROM_BUFFER[0]);
//printf("\nFAMILY_CODE_DATA = %x", ROM_BUFFER[7]);
delay_ms(2000);
DS2411_DATA = b7dfaeb6af55
CRC_DATA = 55
FAMILY_CODE_DATA = aa
DS2411_DATA = adf7ebab6fd5
CRC_DATA = 55
********************************** Initialization ******************************
void init(void)
output_low(DS2411_IO);
*************************************** Reset **********************************
int8 Reset(void)
int8 result=0;
output_low(DS2411_IO); // Drives DQ low
delay_us(480);
output_high(DS2411_IO); // Releases the bus
delay_us(60);
// Sample and return the Presence Detect
result=input(DS2411_IO) & 0x01;
delay_us(240);
return result;
*************************************** Write1 *********************************
void Write1(void)
delay_us(1);
delay_us(59);
*************************************** Write0 *********************************
void Write0(void)
delay_us(55);
delay_us(5);
**************************************** Readx *********************************
int8 Readx(void)
int8 result=0;
delay_us(1);
delay_us(14);
delay_us(45);
return result;
************************************* WriteByte ********************************
void WriteByte(int8 Data)
int8 loop;
for(loop = 0;loop < 8;loop++)
// 0x01,0x02,0x04,0x08,0x10,etc.
if(Data&(0x01 << loop)) Write1();
else Write0();
************************************** ReadByte ********************************
int8 ReadByte(void)
int8 loop;
int8 result=0;
for(loop = 0;loop < 8;loop++) result = result + (Readx() << loop);
return result;
jds-pic
global
Posted: Tue Mar 29, 2005 9:32 am |
| Thanks for the links ! I'll do what i can |
