pcw error
fastlink
pcw error
PostPosted: Sun Sep 23, 2001 9:19 am     Reply with quote
i've installed pcw vs 3.44, all ok, but when i try to start it a message appear 'access violation at address xxxxx in module 'pcw.exe'. read of address 00000000'
why this?
if i try to compile i receive the same message.
thanks
___________________________
Original Post ID: 352
BobbyF
PostPosted: Wed Mar 23, 2005 7:30 am     Reply with quote
I get the same message..
I'm running with Win XP SP2, I tried to uninstall/reinstall, with different releases of the compiler but i always get the same error.
If I try to compile from MPLAB, it does nearly the same error, but with 'CCSC.exe' instead of 'Pcw.exe'.
The PC is brand new.. so quite clean!
An idea to fix this?
thanx a lot!
BobbyF
BobbyF
PostPosted: Thu Mar 24, 2005 7:08 am     Reply with quote
up...
I already read other topics about access violation but none was useful for me.
any idea?
BobbyF
PostPosted: Mon Apr 04, 2005 6:54 am     Reply with quote
found !
some files were corrupted at the installation.. so I got right files from another computer and then it worked. hope it will be useful for someone else...
