60hz clock
thiaguetz
60hz clock
PostPosted: Tue Mar 22, 2005 9:17 am     Reply with quote
hi,
I want to make my PIC (16F628) oscillate at 60Hz and a timer that pulse every 0,5 second.
Anybody have an ideia on how to make this work?
Thanks!
valemike
PostPosted: Tue Mar 22, 2005 9:49 am     Reply with quote
The cheapest way to do it would to go off one winding of your transformer's secondary (i hope it's 24Vac or below), and put it in series with a somewhat big resistor, say 100Kohm, directly to RB0.
yeah it exceeds the ratings, but you do have internal clamping diodes to a diode drop below and above ground, and your current will be really limited by the resistor.
And since it's a schmitt trigger input, you'll have something like 6ms low and 10ms high, but your transitions will be a consistent 60Hz.
-Mike
PostPosted: Tue Mar 22, 2005 11:06 am     Reply with quote
mmmm...
but, is there a way to do it using only clock settings on the software side?
And about the timer?
thanks
rwyoung
PostPosted: Tue Mar 22, 2005 1:11 pm     Reply with quote
Look for code in the Library / Code Snippit forum. I think it was Neutone that posted some very good no-error RTC code using the PIC's timers.
If it wasn't Neutone, then I appologize for not giving credit to the correct author.
Rob Young
