mbogucki Guest
ADC values negative in range of (127 to 255) |
Posted: Sat Mar 19, 2005 9:49 pm |
Hi All,
We've been attempting to solve a "simple" mystery. In the process of creating a simple datalogger, we've used the ex_admm.c example as our base code.
When using the example outright, everything looks good, but the output is in hex. We've changed the code from:
printf("\n\rMin: %2X Max: %2X\r\n",min,max);
to
printf("\n\rMin: %2d Max: %2d\r\n",min,max);
in order to see everything in decimal.
When running, the output is fine when our range is from 0 to 127, but when we go beyond this, the values are now -127 -- 0...
Can anyone shed some light on this mystery?
In terms of hardware, we are using a pic 16f876. and our compiler is version
PCM compiler version 3.163
Thank you very much for your time and support.
--Mike Bogucki |
Posted: Sat Mar 19, 2005 10:13 pm |
In CCS, to display unsigned 8-bit values with printf(), you use: "%u"
To display unsigned 16-bit or 32-bit values, you use: "%lu" |
mbogucki Guest
ADC negative values.... THANKS!!! :) |
Posted: Tue Apr 05, 2005 7:50 am |
Hi PCM Programmer,
Sorry for the long delayed response...
Thank you very much for the suggested solution. It worked like a charm!!!
--Mike
![Smile](images/smiles/icon_smile.gif) |
