18F442 and LCD.C not works
Guard
PostPosted: Fri Mar 18, 2005 8:38 am     Reply with quote
PCWH 3.221
My lcd don't work !,
The hardware is ok, I tested it by asm routine
Where is the error in my code?
Thanks!
  struct lcd_map {               //   This structure is overlayed
         int     data : 4;
         boolean D4; // non usato per lcd
         boolean D5; // non usato per lcd
         boolean D6; // non usato per lcd
         boolean D7;
                   } lcd;
#byte lcd=0xf83
#byte PORTC=0xf82
#BIT RS= PORTC.5
#BIT E= PORTC.6
restart_wdt();
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // The following are used for setting
                             // the I/O port direction register.
STRUCT lcd_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
void lcd_send_nibble( byte n ) {
      lcd.data = n;
      delay_us(10) ; //2
RESTART_WDT();
  output_high(PIN_C6);
      delay_us(10); //2
  output_low(PIN_C6);
void lcd_send_byte( byte address, byte n ) {
RESTART_WDT();
      rs = 0;
   delay_us(50);
     rs = address;
      delay_us(25);//2
      delay_us(15); //2
  output_low(PIN_C6);
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    byte i;
    set_tris_C(LCD_WRITE);
    set_tris_D(LCD_WRITE);
    rs = 0;
  output_low(PIN_C6);
    delay_ms(50);
RESTART_WDT();
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5); //5
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( byte x, byte y) {
   byte address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
RESTART_WDT();
void lcd_putc( char c) {
 switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     default     : lcd_send_byte(1,c);     break;
Mark
PostPosted: Sat Mar 19, 2005 7:52 pm     Reply with quote
Take a look at this and change the pins to match your connections
http://www.ccsinfo.com/forum/viewtopic.php?t=20182
