port pin remapping
jbmiller
port pin remapping
PostPosted: Fri Mar 18, 2005 10:15 am     Reply with quote
Ok, I know it's 'somewhere' here....I've been searching for the discussion on how to remap all the port pins as a 'group', but I can't find it. Using 'remap' as a search word doesn't help.Can someone please point me in the right direction? I need to remap Port B so the data comes out exactly opposite( B0=data7,b1=data6,...B7=data0).
Thanks to all...
Jay
PostPosted: Fri Mar 18, 2005 11:46 am     Reply with quote
Probably these two threads will give you some ideas:
http://www.ccsinfo.com/forum/viewtopic.php?t=4879
http://www.ccsinfo.com/forum/viewtopic.php?t=18949
jbmiller
io pin remapping
PostPosted: Fri Mar 18, 2005 3:58 pm     Reply with quote
thanks PCM programmer ! I KNEW it was 'somewhere', though I hadn't thought about the code area. Man, having seniors moments really is a pain. this time I've bookmarked it, copied it t my desktop and I will print it out too! it's a handy code snippet that I need .
Jay
