fast i2c question
guest
fast i2c question
PostPosted: Fri Mar 18, 2005 6:23 am     Reply with quote
Hi to all.
I am reading/writing to a 24lc256 eeprom , and have a few questions.
When I write and then read back the whole 32768 bytes it takes
about 2 min 45 sec .
this is the basic code:
for(i=0;i<32767;i++)
write_ext_eeprom (i,100);
tmp = read_ext_eeprom(i);
the i2c is set up like this:
#use i2c(MASTER,sda=EEPROM_SDA,scl=EEPROM_SCL)
if I now set up the i2c like this
#use i2c(FAST , MASTER,sda=EEPROM_SDA,scl=EEPROM_SCL)
the test takes about 2min 20 sec.
The fast option only increaced the speed by about 15% or so.
Is this right , or is there something else I can do to make the i2c routines run faster.
Cheers
Rob
PostPosted: Fri Mar 18, 2005 6:28 am     Reply with quote
The slowest thing here is the chip itself. The I2C speed only affects the communications, and on 'read' cycles, will save a lot (typically 75%). Most of the time you are seeing is the write time of the chip itself, which is typically in the order of 5mSec/byte. There is nothing you can do to change this, except use a different memory technology. Look at 'FRAM' chips, which have write times vastly better.
PostPosted: Fri Mar 18, 2005 6:58 am     Reply with quote
Hi there , thanks for the reply.
I just redid the speed test , after commenting out the write command and the speed was doubled with the fast option , which matches up with what you say.
Now to throw a spanner in the works as it were.
I just programmed AND verified the same chip(24lc256) from address
0 to 7fff ( 32k) in a chipmax programmer in under 10 seconds!!!!
How do they manage that?
Cheers
Rob
Mark
PostPosted: Fri Mar 18, 2005 7:04 am     Reply with quote
Not entirely true. You can write by pages to speed things up.
Cheers
Rob
Same answer, page mode.
guest
PostPosted: Fri Mar 18, 2005 7:12 am     Reply with quote
Thanks , things are starting to make sence.
Does CCS support page writing at all?
Cheers
Rob
Mark
PostPosted: Fri Mar 18, 2005 7:14 am     Reply with quote
Depends on what you mean by support. There isn't a function called "write_page" but you can easily do it in C. There should be code already posted in the forum for doing it.
PostPosted: Fri Mar 18, 2005 7:35 am     Reply with quote
Yes. Page mode is the way to go if you are writing a lot of data. I was (of course), referring to the timing in the example given which is 'byte by byte'. The saving for page mode depends on the actual page size of the chip, but most of the larger chips support a 64 byte mode, and this makes a huge saving. On most chips all that is needed, is to send the control word, address, and data byte as normal, but then not send the stop, but instead carry on sending another 63 bytes of data. Sending the stop at the end of this triggers the 'page write'. This takes the same time as a single byte write...
The code would be something like:
void write_page_ext_eeprom(long int address, BYTE data[])
   short int status;
   int count;
   i2c_start();
   i2c_write(0xa0);
   i2c_write(address>>8);
   i2c_write(address);
   for (count=0;count<64;)
       i2c_write(data[count++]);
   i2c_stop();
   i2c_start();
   status=i2c_write(0xa0);
   while(status==1)
   i2c_start();
I used something like this on another chip in the past, and it worked fine, so it should be a starting position for you. Obviously it needs to be called with the address, and an array of 64 bytes.
Mark
PostPosted: Fri Mar 18, 2005 9:09 am     Reply with quote
   short int status;
   int count;
   i2c_start();
   i2c_write(0xa0);
   i2c_write(address);
   i2c_stop();
   i2c_start();
   while(status==1)
   i2c_start();
You should be sure not to exceed the page size or the buffer will wrap and overwrite an area not intended. Something like:
  DESCRIPTION:  This function writes a block of data to the SEEPROM
  RETURN: none
  ALGORITHM:  none
  NOTES:  The routine should handle going across chip boundaries
void I2C_Write_Block(
  uint8_t   device,   /* I2C address of the device that we are writing to */
  char    *data,    /* pointer to the block of data to write */
  uint8_t   len,      /* number of bytes to write */
  uint16_t  address)  /* EEPROM address to write data */
  uint8_t control;
  uint8_t lastpage;
  uint8_t page;
  /* determine the control word for the device */
  control = device | ((uint8_t) (address >> 8) << 1);
  /* Wait until our device is ready */
  while (!I2C_Device_Ready(control));
  /* Set the address pointer in the device */
  I2C_WRITE((uint8_t) address);
  page = (uint8_t) address >> 4;
  lastpage = page;
  while (len)
    if (page != lastpage)
      /* Issuing a STOP will start the write sequence */
      I2C_STOP();
      lastpage = page;
    I2C_WRITE(*data);
    data++;
    address++;
    /* The 24C08 has a 16 byte page for writing. */
    len--;
  I2C_STOP();
