garret
LCD with PIC18F6490 |
Posted: Fri Mar 18, 2005 7:34 am |
i'm trying to drive a LCD varitronix VIM828 with the PIC18LF6490. I'm using PCWH ver 3.214 with MPLAB v.7.01. I've use this code:
#include <18f6490.h>
#fuses HS,NOWDT,NOPROTECT
byte CONST DIGIT_MAP[8] = {0x90,0xb7,0x19,0x36,0x45,0xff,0x00,0xaa};
#define DIGIT_1_CONFIG COM3+31,COM2+10,COM0+2,COM1+20,COM1+1,COM1+28,COM1+3,COM2+0
int i = 0;
setup_lcd(LCD_MUX14,1,ALL_LCD_PINS);
while (true)
for(i = 0; i<8; i++)
LCD_SYMBOL(0xff,DIGIT_1_CONFIG);
output_bit(PIN_C0,0);
output_bit(PIN_C1,1);
output_bit(PIN_C0,1);
output_bit(PIN_C1,0);
Someone know why I can't display nothing on the glass?
I connect bias resistor exactly like shown on page 263 of the data sheet.
I can't see any signal on the pin of the chip?
SOmeone can help me?
Thank you in advance
Roberto |
speedblue Guest
Re: LCD with PIC18F6490 |
Posted: Mon May 30, 2005 9:59 am |
garret wrote: | Hello,
int i = 0;
while (true)
Roberto |
// in CCS PCWH 3.212
#BYTE LCDSE0= 0xF5A
#BYTE LCDSE1= 0xF5B
#BYTE LCDSE2= 0xF5C
#BYTE LCDSE3= 0xF5D
void main() {
LCDSE0=0b11111111;
LCDSE1=0b11111111;
LCDSE2=0b11111101;
LCDSE3=0b11111111;
setup_lcd(LCD_MUX14|STOP_ON_SLEEP|USE_TIMER_1);
