ADC of PIC18F8720
rafa2
ADC of PIC18F8720
PostPosted: Wed Mar 16, 2005 12:13 pm     Reply with quote
I have a doubt about the ADC of a PIC18F8720. There are a little offset between the real signal and the value measured, for example if the voltage at input is 1.414V, the measure is 1.504. The precision is 1/2 bit = 4/1024/2=2mV.
The configuration is: Vref+ = external ref = 4V (from a zener); Vref- = internal ref = VSS. Also, the micro have VDD = 5V, but the ICD2 only delivery 4.74V. If I change the configuration and the references are internal (VSS and VDD) the results are worse.
My code is:
#define ANALOG_AN0_TO_AN5   0x09
#define VSS_VDD         0x00
#define VSS_VREF         0x10
#define ADC_CLOCK_DIV_32   0x102
#include <18f8720.h>
#device *=16 ADC=10
#FUSES HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
#ID CHECKSUM
#ZERO_RAM
#use DELAY(CLOCK=20000000)
#use RS232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7)
void main (void){
   int16 val;
   set_tris_a(0xFF);
   setup_port_a( ANALOG_AN0_TO_AN5 | VSS_VREF);
//   setup_port_a( ANALOG_AN0_TO_AN5 | VSS_VDD);
   setup_adc( ADC_CLOCK_DIV_32 );
   while(1){
      set_adc_channel( 4 );
      delay_ms(10);
      val=read_adc();
      delay_ms(10);
      printf(displays,"%Lx",val);
      printf("%2.3f",(float)val*3.99/1024);
//      printf("%2.3f",(float)val*4.74/1024);
Some idea???
DragonPIC
PostPosted: Wed Mar 16, 2005 1:15 pm     Reply with quote
There have been some post earlier that claim problems with floating points with prontf(); look in some recent posts.
http://www.ccsinfo.com/forum/viewtopic.php?t=22210
If this is how you are reading your answer, beware.
-Matt
bluetooth
PostPosted: Wed Mar 16, 2005 4:22 pm     Reply with quote
What is the int16 val when you have 1.414v input? Is it what you expect? With a 4v reference, I think you should read 362. I guess I don't exactly understand why your resolution ("precision") isn't 4/1024 or 3.9mV.
Verify this before you worry about the (potential) printf/float issue....
rafa2
PostPosted: Wed Mar 16, 2005 4:29 pm     Reply with quote
I think that the problem is the converter. In the code, I can see the measure directly from a converter (printf("%Lx",val); ), and for 1.4V it should be: 1.414*1023/4=361=169h, and I read 182h.
PostPosted: Wed Mar 16, 2005 4:40 pm     Reply with quote
You are trying to get 4 digits of precision in your result, but your
posted zener voltage only has one digit.
Also if I go to http://www.digikey.com and type in Zener Diode
and look at the available voltages, I see 3.9v and 4.3v, but no 4.0v.
In addition to that problem, the typical tolerance is 5%.
What is your true Vref voltage, as measured with a voltmeter ?
bluetooth
PostPosted: Wed Mar 16, 2005 4:41 pm     Reply with quote
Good info... now you might look at the input and your supplies with a 'scope to make sure they're steady and noise free, and make sure you're driving the input with an impedance that's < 2.5k ohms...
Adding:
PCM is probably on it... with a 3.9V zener you'll read 371, if it's exactly 3.9V... the tolerance is probably the rest of the error.....
rafa2
PostPosted: Wed Mar 16, 2005 4:46 pm     Reply with quote
Perdon, it is a regulator not a zener, with a voltmeter 3.99V.
rafa2
PostPosted: Wed Mar 16, 2005 4:50 pm     Reply with quote
And the input have a op-amp...
bluetooth
PostPosted: Wed Mar 16, 2005 5:01 pm     Reply with quote
Rafa2:
You're killing all the theories!!!!!
OK - silly question, but are AVss and AVdd hooked up via a low impedance path? And are all signals stable and quiet? It starts to sound more like a power/ground problem....
Happy hunting....
PostPosted: Wed Mar 16, 2005 5:09 pm     Reply with quote
What's your version of the compiler ?
Post the portion of the .LST file that shows the ASM code for the lines
given below. It's possible that the ASM code for the A/D functions is
incorrect. If you post it, maybe we can see the problem.
set_tris_a(0xFF);
while(1){
delay_ms(10);
val=read_adc();
rafa2
PostPosted: Wed Mar 16, 2005 5:23 pm     Reply with quote
I am sorry for your theories, bluetooth... Embarassed
About the power supply, unless the ICD2 only delivery 4.7V
The version of the compiler is 3.180
LST:
....................       set_tris_c(0x10);
0702:  MOVLW  10
0704:  MOVWF  F94
....................       set_tris_a(0xFF);
0706:  MOVLW  FF
0708:  MOVWF  F92
....................    setup_port_a( ANALOG_AN0_TO_AN5 | VSS_VREF);
070A:  MOVF   FC1,W
070C:  ANDLW  C0
070E:  IORLW  19
0710:  MOVWF  FC1
.................... //   setup_port_a( ANALOG_AN0_TO_AN5 | VSS_VDD);
....................    setup_adc( ADC_CLOCK_DIV_32 );
0712:  BCF    FC0.0
0714:  BSF    FC0.1
0716:  BCF    FC0.2
0718:  BSF    FC0.7
071A:  BSF    FC2.0
.................... //   ADCON0 = 0x11; // set up adc, timer/32, and adc on
.................... //   ADCON1 = 0x00; // right justified result, a0,1,4 are analog, a2,3 are references, e0,e1,e2 are digital
.................... //   ADCON2 = 0x82;
....................    set_adc_channel( 4 );
071C:  MOVLW  10
071E:  MOVWF  01
0720:  MOVF   FC2,W
0722:  ANDLW  C3
0724:  IORWF  01,W
0726:  MOVWF  FC2
....................    LCD_E = 1;                  // enable LCD
0728:  BSF    F82.2
....................    disp_lcd = TRUE;
072A:  BSF    05.0
....................    disp_serial = false;
072C:  BCF    05.1
....................    init_lcd();
072E:  BRA    007C
....................    while(1){
0730:  MOVLW  10
0732:  MOVWF  01
0734:  MOVF   FC2,W
0736:  ANDLW  C3
0738:  IORWF  01,W
073A:  MOVWF  FC2
....................       delay_ms(10);
073C:  MOVLW  0A
073E:  MOVWF  28
0740:  RCALL  0004
....................       val=read_adc();
0742:  BSF    FC2.1
0744:  BTFSC  FC2.1
0746:  BRA    0744
0748:  MOVFF  FC3,06
074C:  MOVFF  FC4,07
0750:  MOVLW  0A
0752:  MOVWF  28
0754:  RCALL  0004
Rafa
bluetooth
PostPosted: Wed Mar 16, 2005 5:36 pm     Reply with quote
Rafa2:
Looks like those setups are good - and since you're using an external VREF, the ICD power shouldn't matter.... so, back to my original questions: are AVss and AVdd connected via low impedance paths, and are all the signals stable and quiet when looked at on a 'scope?
