Using a different crystal oscillator
PostPosted: Tue Mar 15, 2005 3:05 pm     Reply with quote
I have a PIC18f458 and was using a 20Mhz crystal oscillator. Will it make any difference in my program if I use a 16Mhz or 24Mhz oscillator?
PostPosted: Tue Mar 15, 2005 3:06 pm     Reply with quote
You need to change the #use delay() statement to match your
new crystal frequency.
Mark
PostPosted: Tue Mar 15, 2005 3:19 pm     Reply with quote
Depends on what your program does. It will affect the speed of your timers/counter/pwms. The baud rate generators will have different values as well. If you use the #use rs232 to set the speed then you won't have a problem. If you set the SPBRG value yourself, then you will have to compute the new value.
