LCD problems
LCD problems
PostPosted: Thu Mar 03, 2005 3:56 am     Reply with quote
Hi all. I seem to be having problems getting an lcd to work properly.
I am using a 1602 series lcd's 16*2 lines connected to port b. I am using the lcd driver provided by CCS. ( ver 3.207)
The lcd.c file in this version is slightly different from a previous one I used(unfortunately I can't remember the previous ver Sad , I think it was 3.187)
With the previous version I did not have any problems...
The LCD structure is set up like this:
struct lcd_pin_map {
                                  int     data : 4;
                                  BOOLEAN enable;
                                 BOOLEAN rs;
                                 BOOLEAN rw;
                                 BOOLEAN unused;
                          } lcd;
With this structure the lcd WON'T work.
If I set up the lcd like this:
BOOLEAN enable;
BOOLEAN rs;
BOOLEAN rw;
BOOLEAN unused;
int data : 4;
} lcd;
Then the lcd works fine. Obviously I change the wiring to match the STRUCT!!!
With the previous version I could move the (DATA:4) , and rs , rw , e at will with no probs.
Any ideas what I'm doing wrong.
Cheers
Rob
Mark
PostPosted: Thu Mar 03, 2005 6:59 am     Reply with quote
Well I think I have 3.217 installed and the LCD.C file has a date of June 2003 so I do not believe they changed it. My guess is that you are not changing the LCD_READ and LCD_WRITE constants which control the tris registers.
DavidHudd
PostPosted: Tue Mar 15, 2005 12:56 pm     Reply with quote
The reason it does not work is that the driver assumes the data nibble is D5-7 and does operations (e.g. on tris) without refering to the structure you modified.
You will need to do more extinsive changes to the driver or change the wiring.
Mark
PostPosted: Tue Mar 15, 2005 1:22 pm     Reply with quote
No way, the driver does not assume at all. None of the code has to be changed at all. Only as I said before
