I'm using a 18f4431 and when I read the 18fxx31 datasheet I've noticed that there was different adresses for the same register (http://ww1.microchip.com/downloads/en/DeviceDoc/39616b.pdf).
For example, the register SSPCON had the address FC6h at the page 67 (register map) and on the page 215 (register 18-2) it had the address 14h.
With Mplab the first address seems to work but in every application I've seen evrybody use the second. What address should I use?
Am I going crazy or is it totally normal and I don't know how to read a datasheet ?
Posted: Sun Mar 13, 2005 3:03 pm
No, I saw it too, when I was recently working on a 18F4431 problem
for someone on this board. What you're seeing is laziness by the
tech writer at Microchip. They must have copied a section of the
SSPCON data sheet from a 16F series PIC where the SSPCON address
is normally at 0x14.
