Hi, Im having problems writing some code to send a 12f683 to sleep after 2 min's using timer2 although the problem is that i need to do it without useing any of the ccs functions can any one help
Regards
Michael Dale
valemike Guest
Posted: Mon Mar 07, 2005 3:05 pm
Why can't you use CCS's libraries?
mjdale2003
problem
Posted: Tue Mar 08, 2005 3:29 am
i am using a 12f683 although the compiler version does not support this chip and the trouble iv had getting other functions to work i think ill just go around the problem, if u think the functions will work could u please post a short peice of code that will flash an led at a certain interval
Regards
Michael
Mark
