bhyatyab
| Timers |
Posted: Mon Mar 07, 2005 1:32 am |
Hi
I need some help using timers. Say I want some code to run after 10 minutes - will this work?
int secs;
int mins;
int hrs;
#int_RTCC
RTCC_isr() {
set_timer1(0*8000);
#int_TIMER1
TIMER1_isr() {
set_timer1(0*8000);
secs=secs+1;
if (secs==60){mins=mins+1;secs=0;}
if (mins==60){hrs=hrs+1;mins=0;}
if (hrs==24){hrs=0;}
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
enable_interrupts(INT_EXT);
enable_interrupts(INT_EXT1);
enable_interrupts(INT_EXT2);
enable_interrupts(GLOBAL); |
Posted: Mon Mar 07, 2005 3:21 am |
First a remark: When posting code, please use the Code button, this will ensure your identation is preserved and makes the code easier to read.
Second remark: When posting code on this forum, please post a COMPLETE working example and tell us which processor you are using, sometimes it is also helpfull to post your compiler version.
What clock frequency are you running?
Your example has several problems:
1) You have disabled timer1, so the timer1_interrupt will never fire.
2) '0*8000' equals 0, what do you want to achieve here?
3) Using the timer0 interrupt to change the value of timer1?????????? Don't do this.
4) You haven't adjusted the timer rates for your clock frequency, this requires setting the pre- and/or postscaler division ratios. Read the documentation on the setup_timer_x functions.
Basically I advise you to study the examples you will find when searching this forum with the keywords 'real time clock' or 'rtc'. |
bhyatyab
| Timers |
Posted: Mon Mar 07, 2005 3:40 am |
Hi
Sorry, Im using a 18F452. I want to implement a timer - something must happen after 24hrs - can you guide me.
Thanks |
Posted: Mon Mar 07, 2005 5:10 am |
And you still have not told us the clock rate?...
bhyatyab
| Timers |
Posted: Mon Mar 07, 2005 5:34 am |
| Clock rate is 20Mhz |
Posted: Mon Mar 07, 2005 5:57 am |
#include <18F452.h>
#device adc=8
#fuses HS,PUT,BROWNOUT,NOWDT,WDT1
int16 tick;
int16 seconds;
#define TICKS_PER_SECOND (1000)
//With a 20MHz clock/16, with the timer counting 0...249, and interrupting on
//every tenth reset, this gives:
//((20000000/16)/250)/10 times per second = 1000
#define TIME_I_WANT_TO_WAIT (600)
//For ten minutes
#int_timer2
void tick_handler(void) {
if(tick) {
tick--;
else {
tick=(TICKS_PER_SECOND-1)
if (seconds) --seconds;
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_wdt(WDT_OFF);
setup_timer_2(T2_DIV_BY_16,249,10);
while(1) {
seconds=TIME_I_WANT_TO_WAIT;
while (seconds) ;
//You get here when 'seconds' reaches zero
Shows one approach |
Posted: Mon Mar 07, 2005 6:20 am |
In main() the code for enabling the timer2 interrupts is missing: | Code: | enable_interrupts(INT_TIMER2);
And one small suggestion, change | Code: | | setup_timer_0(RTCC_INTERNAL); | to | Code: | | setup_timer_0(RTCC_OFF); |
Posted: Mon Mar 07, 2005 8:53 am |
I agree.
I used the 'wizard' to generate the framework, and hadn't bothered to check. :-)
