page writes to eeprom
PostPosted: Sun Mar 06, 2005 12:35 am     Reply with quote
does anyone know how write to the external eeprom in page mode?
Re: page writes to eeprom
PostPosted: Sun Mar 06, 2005 4:41 am     Reply with quote
Which external eeprom do you mean? Do you have a type number for us?
rwyoung
PostPosted: Sun Mar 06, 2005 8:53 am     Reply with quote
If you mean something related to the 24C64/128/256 (the only ones I've tested this with) it is pretty easy but I was a little bit lazy and didn't try writing it in a more RAM efficient way since this particular routine is being used on a PIC18 and I am only expecting to be using about 25% of total RAM anyway.
 * void writepage_ext_eeprom(long int address, char *data)
 * Purpose    : Write 64 byte page to  external EEPROM at particular address.
 *              Uses ACK polling to find end of eeprom write cycle.
 * Parameters : address - 16 bit int for address
 *              *data - pointer to array of 64 bytes to write
 * Calls      : various
 * Returns    : none
 * Notes      : TODO : change device address to #def'd value
 * Tested     :
   int8 i;
   i2c_start();
   i2c_write(0xA0);
   i2c_write(make8(address,1));
   i2c_write(make8(address,0));
   for(i=0;i<64;i++)
      i2c_write(data[i]);
   i2c_stop();
   // eeprom ACK polling
   do {
      i2c_start();
   } while(i2c_write(0xA0));
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
Mark
PostPosted: Sun Mar 06, 2005 9:21 am     Reply with quote
Here are some code snippets that if you read them will give you idea of what to do. Note that the page size is dependant upon the chip used. I believe this code was for a 24C08 (actually 2 of them)
#define I2C_IDLE()  while ((SSPCON2 & 0x1F) || (SSPSTATbits.R_W))
#define I2C_START() \
  SSPCON2bits.SEN = 1; \
while (SSPCON2bits.SEN) \
  _asm nop _endasm \
#define I2C_RESTART() \
  SSPCON2bits.RSEN = 1; \
  while (SSPCON2bits.RSEN) \
    _asm nop _endasm \
#define I2C_STOP() \
  SSPCON2bits.PEN = 1; \
  while (SSPCON2bits.PEN) \
    _asm nop _endasm \
#define I2C_WRITE(x) \
  SSPBUF = (x); \
  while (SSPSTATbits.BF) \
    _asm nop _endasm \
  I2C_IDLE()
#define I2C_READ(x) \
  SSPCON2bits.RCEN = 1; \
  while (SSPCON2bits.RCEN) \
    _asm nop _endasm \
  SSPCON2bits.ACKDT = (x); \
  SSPCON2bits.ACKEN = 1; \
  while (SSPCON2bits.ACKEN) \
    _asm nop _endasm \
  DESCRIPTION:  This function writes a block of data to the SEEPROM
  RETURN: none
  ALGORITHM:  none
  NOTES:  The routine should handle going across chip boundaries
void I2C_Write_Block(
  uint8_t   device,   /* I2C address of the device that we are writing to */
  char    *data,    /* pointer to the block of data to write */
  uint8_t   len,      /* number of bytes to write */
  uint16_t  address)  /* EEPROM address to write data */
  uint8_t control;
  uint8_t lastpage;
  uint8_t page;
  /* determine the control word for the device */
  control = device | ((uint8_t) (address >> 8) << 1);
  /* Wait until our device is ready */
  while (!I2C_Device_Ready(control));
  /* Set the address pointer in the device */
  I2C_WRITE((uint8_t) address);
  page = (uint8_t) address >> 4;
  lastpage = page;
  while (len)
    if (page != lastpage)
      /* Issuing a STOP will start the write sequence */
      I2C_STOP();
      lastpage = page;
    I2C_WRITE(*data);
    data++;
    address++;
    /* The 24C08 has a 16 byte page for writing. */
    len--;
  I2C_STOP();
  DESCRIPTION:  This function checks to see if an i2c device will ACK
  RETURN: TRUE if device ACKed otherwise FALSE
  ALGORITHM:  none
  NOTES:  none
static bool I2C_Device_Ready(
  uint8_t id) /* FIX ME: add comment */
  do
    /* Important to clear these bits before we attempt to write */
    PIR2bits.BCLIF = 0;
    SSPCON1bits.WCOL = 0;
    I2C_IDLE();             /* ensure module is idle */
    I2C_START();
  } while (PIR2bits.BCLIF);
  I2C_WRITE(id);
  if (!SSPCON2bits.ACKSTAT) /* test for ACK condition, if received */
    return (TRUE);
  return (FALSE);
drolleman
PostPosted: Sun Mar 06, 2005 11:43 am     Reply with quote
thank for the info, it's just what i needed
