it failed with version ???
but i do know it failed with 3.190 and later
I put this code to work it out now
if(n & 1) LcdD4 = 1; else LcdD4 = 0;
Posted: Sat Mar 05, 2005 3:08 pm
This was reported at the time. It was a deliberate change, apparently to actually bring the compiler closer to ANSI in some way, but it results in arithmetic, that doesn't happen to 'hit' the bit used by an int1, resulting in a false. Use:
LcdD4=((n&1)!=0).
This should result in a faster version than the if test.
