young
wireless recv idle problem |
Posted: Fri Mar 04, 2005 8:41 am |
I have two set up no wireless communication, one setup is clear that when there is no data, receivere side is idle as high, which I success in data collection. another when it is in idle it is some kind of square wave, I did not know where these square come from, and I think in idle state it should either high or low there should not be waves. please advice what might casue this problem.
sincerely |
Humberto
Posted: Fri Mar 04, 2005 8:58 am |
Hola joung,
Using a small non-magnetic screwdriver re-tune the variable
tunning capacitor in the Rx module front end while watching the
output with a scope.
Humberto |
Posted: Fri Mar 04, 2005 9:16 am |
I tried to switch the one which have the ideal idle (high) with this one that has square wave idle, but the same thing happened. I will try to tunning the RX modual as you suggested.
thank you |
Posted: Fri Mar 04, 2005 12:25 pm |
I was tunning my program and I am able to get data at the very beginning, however, after a while the data changes to something weired, please help with possible reasons
Quote: |
1T3Z 114.71T4Z 75.71T5Z 16.71T6Z 217.71T7Z 118.71T8ZÿÿãrC£õ 412.71T2Z 513.71T3Z 114.71T4Z 75.71T5Z 16.71T6Z 217.71T
7Z 118.71T8ZÿÿÿÿÿÿãrC£B#ãrC%£R3ãrC5£11111111111111111111111111111111111111111111111111111111111111111111111111111111111111
