? Optimization ?
future
? Optimization ?
PostPosted: Wed Mar 02, 2005 11:37 am     Reply with quote
While doing some changes to my code, I noticed this:
#opt 11
struct data_t {
   unsigned char active:1;
   unsigned long delay;
   unsigned long duration;
struct data_t a;
struct data_t b;
a = b;
0848:  CLRF   FSR0H
084A:  MOVLW  a
084C:  MOVWF  FSR0L
084E:  CLRF   FSR1H
0850:  MOVLW  b
0852:  MOVWF  FSR1L
0854:  MOVLW  06
0856:  MOVWF  @01
0858:  MOVFF  POSTINC1,POSTINC0
085C:  DECFSZ @01,F
085E:  BRA    0858
Is that correct? I think it should be 5 MOVFF's.
Neutone
PostPosted: Wed Mar 02, 2005 12:23 pm     Reply with quote
When you are making a copy of an array of bytes, the optimizer should switch to from using indirect addressing to direct memory addressing when the number of bytes copied is greater than 11. That is true for the example you posted at least. That will optimize for code size.
future
PostPosted: Wed Mar 02, 2005 6:59 pm     Reply with quote
But if 5 MOVFF's were used, the code would be faster/smaller, dont you think?
bluetooth
PostPosted: Wed Mar 02, 2005 8:09 pm     Reply with quote
Future:
Grab any decent text on compiler design - you'll discover there's a HUGE distance between code optimized in an application specific environment by a professional assembly programmer and code from a generic set of statements fed to an optimizer that (obviously) must work after optimization - no matter how complex the (unknown to the compiler author) statements are!
CCS does an amazingly good job for a multi-hundred $$ compiler - we've used Greenhills in the past for 68xxx and it was better - but we paid a WHOLE lot more for that environment.
If you want "optimal" optimization, write the code in assembler. But remember, it'll probably take longer to write and debug, there's always one more byte that can be squeezed out by some wiseguy Cool
The real question to be asked is: does the code work under the conditions required? And did using the compiler get you there quicker than writing it in assembler? If both answers are yes, then mission accomplished.
Just my $0.02....
PostPosted: Thu Mar 03, 2005 2:52 am     Reply with quote
Your example shows 24 bytes used. Using movff's is more efficient when copying up to 6 bytes. So yes, the compiler is not generating the most optimized code here.
CCS has improved the optimization a lot in v3.200, but there is always room for further improvement. Remember that the compiler is generating correct working code, optimization is just a nice bonus. That being said, it never hurts to send CCS a nice email pointing them at possible improvements, you may be lucky in the next release...
