glenjoy
RS232 Interrupt on CCS C |
Posted: Wed Mar 02, 2005 8:18 am |
I want to implement a serial routine in my program; it is getting a character from the serial port, now while waiting for the incoming serial data, I still want to monitor some important event outside my microcontroller, how to implement this w/o this:
main
char x;
x = getc();
Because as far as I know the program will stop at at getc() and will wait for an input before it will got to the next line. |
Kasper
Joined: 14 Jan 2004 Posts: 88 Location: Aurora, Ontario, Canada
Posted: Wed Mar 02, 2005 8:59 am |
set up the serial receive interrupt
#use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, stream=PORT1, bits=8, errors)
void main(void) {
enable_interrupts(INT_RDA);
#int_rda
void handle_data(void) {
char Received;
Received=fgetc(PORT1); // PORT1 is what I called the stream,
[/code] |
SherpaDoug
Posted: Wed Mar 02, 2005 9:02 am |
The key is to call kbhit() to see if a character is available before calling getc()
char x;
if (kbhit()) x = getc();
} _________________ The search for better is endless. Instead simply find very good and get the job done. |
glenjoy
Posted: Wed Mar 02, 2005 9:10 am |
Is the kbhit useful for keyboards input only? whta if the input is not from a PC but from another serial peripherals? |
Posted: Wed Mar 02, 2005 9:14 am |
Bbhit, really has nothing to do with 'keyboards'!. The name dates from the early 'standard' use of 'C', which was assumed to have a serial terminal attached. Hence 'kbhit', just reflects whether there is an incoming character from the serial, which was assumed in this configuration to be a 'keyboard' character.
