Struct question
Struct question
PostPosted: Tue Mar 01, 2005 3:45 am     Reply with quote
HEllo,
///////// Prototipe
Read_pos(); // Can it return 2bit only ,if true , how ?
struct Service
         int  Pos:   2;
         boolean       not used;
         boolean       not used;
         boolean       not used;
         boolean       not used;
         boolean       not used;
         boolean       not used;
      } Srv;
   srv.Pos   =Read_pos();
PostPosted: Tue Mar 01, 2005 8:02 am     Reply with quote
Just return an integer. The compiler (should) truncate it to fit.
Bit fields, are always 'contained' in a larger carrier type (in the case of CCS, an int8, or char type). Hence even if you can declare the smaller type for the return, the result is the whole 'carrier' being returned, and then truncated to fit the location. Hence there is no advantage in returning the smaller type.
