Steps that i have made before programming>
After successfull program compile i went to debugger.
Debugger test was passed. I went to Programmer/Program and this is the result
Programming Target...
...Erasing Part
...Programming Program Memory
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
...Programming RSBUG
...Programming Configuration Bits
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
.. Config Memory
...Programming succeeded
MPLAB ICD 2 Ready
The power supply is switched directly to target application.
Problem:
There's nothing happening (LED should flash ).
I have tryed to programm on the way that i have put extra power supply to ICD2 and the debugging/programming part was passed but again with no result..
Im using 18f452 and this basic demo code:
You don't say whether B2 is blinking or not or if B1 doesn't blink when you get an interrupt...
Delay_ms is not re-entrant, so I wouldn't be surprised if your interrupts are being masked most of the time by the compiler.
You might try replacing the delay_ms(5000) in the interrupt routine with delay_us(50000) - that MIGHT work (although it's going to be shorter!). The real way to do it is to timers so you don't spend scads of time in an interrupt routine!
Good luck...
Mark
Posted: Tue Mar 01, 2005 7:02 am
No fuses, no device statement, I don't see where in the code that you specify the ICD = TRUE or the debug in the fuses. Still not clear if you are using the debugger or not. The info you gave suggests that you are since the debug executive is being loaded. However, you indicate that you program the part from the Programmer menu which would disable the debugger! There was a very early version of MPLAB that allowed the ICD2 to be loaded as a debugger and a programmer but none of the versions now do that.
