Timer1 question
sraiderk
Timer1 question
PostPosted: Fri Feb 25, 2005 9:39 am     Reply with quote
İf I use 16f877 with setting of the timer1 the following
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); //20MHz cristal
104,857ms time later interrupt occurs. My question is that if I define setup_timer with the same configuration like that
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8 |T1_DIV_BY_8);
interrupt occurs at that time later 104,857*8=838,860ms doesn't it?
Humberto
PostPosted: Fri Feb 25, 2005 10:09 am     Reply with quote
Copied from the Compiler HELP:
_____________________________________________________________
SETUP_TIMER_1( )
Syntax:
setup_timer_1 (mode)
Parameters:
mode values may be:
- T1_DISABLED, T1_INTERNAL, T1_EXTERNAL, T1_EXTERNAL_SYNC
- T1_CLK_OUT
- T1_DIV_BY_1, T1_DIV_BY_2, T1_DIV_BY_4, T1_DIV_BY_8
constants from different groups may be or'ed together with |.
Hence, in your expresion:
T1_DIV_BY_8 | T1_DIV_BY_8 Is Not Valid because you are ORed
two constants of the same group.
Humberto
Mark
PostPosted: Fri Feb 25, 2005 10:43 am     Reply with quote
It will actually be the same since oring something with itself is the same. Read the datasheet on the PIC and you will see the available scalers or divide bys.
