Guard
3.219 doesn't recognize INT_COMP2 |
Posted: Thu Feb 24, 2005 1:24 pm |
V 3.219 doesn't recognize enable_interrupts(INT_COMP2).
I try C2IE bit |
Posted: Thu Feb 24, 2005 1:39 pm |
Look at the 16C781.H file. It's not complete. It looks like they
were working on it, but didn't enter the comparator interrupts.
(Actually, I suspect that the .H files are automatically generated
by a program). You should email CCS support about this.
When they fix the comparators in a new version, they will extend
your download rights long enough for you to get the new version.
Code: | // Constants used in ENABLE/DISABLE_INTERRUPTS() are:
#define GLOBAL 0x0B80
#define INT_RTCC 0x0B20
#define INT_RB 0x0B08
#define INT_EXT 0x0B10
#define INT_AD 0x0B40
#define INT_TIMER1 0x8C01
#define INT_LOWVOLT 0x8D80
#define INT_TIMER0 0x0B20
#define INT_ 0x0001
#define INT_ 0x0001 |
Guard
Posted: Thu Feb 24, 2005 1:43 pm |
Can I use COMP2_isr() and C2IE bit ?? |
Posted: Thu Feb 24, 2005 1:48 pm |
You would have to use #INT_DEFAULT, but you're having difficulty
in writing that code, so I think it's better if you ask CCS to make
the comparator interrupts work on the 16C781. Email them. |
Guard
Posted: Thu Feb 24, 2005 2:23 pm |
This is my code for #int default
The PC jump always to interrupt vector !
C2IF is cleared.
I configured all registers for the PSMC , and it works .
C2 and C1 are input for PSMC
#include <16C781.h>
#use delay(clock=10000000)
#fuses NOWDT,HS, PUT,NOPROTECT,MCLR, BROWNOUT, BORV42,
#define ON =1;
#define OFF =0;
static short int Camp;
#byte Port_b = 0x06
#byte portA=5
#byte TRISB =0x86
#byte TRISA =0x85
#byte OPTION=0x81
#bit RBPU=OPTION.7
#byte wpub =0x95
#byte Ansel =0x9d
#bit Fan = Port_B.7
#bit Gate = Port_B.6
#bit pin_datain = Port_B.5
#bit pin_dataout = Port_B.4
///////////////////////////////// A/D
#byte REFCON=0X9B
#byte ADCON0 =0X1F
#bit ADCSL= ADCON0.6
#bit ADCSH= ADCON0.7
#bit CHSH= ADCON0.5
#bit CHSM= ADCON0.4
#bit CHSL= ADCON0.3
#bit GODONE= ADCON0.2
#bit CHS3= ADCON0.1
#bit ADON= ADCON0.0
#byte ADCON1=0X9F
#bit VCFGH= ADCON1.5
#bit VCFGL= ADCON1.4
#byte INTCON = 0x0b
#bit PEIE = INTCON.6
#bit C2IF_BIT = 0x0C.5
#bit C1IF_BIT = 0x0C.4
#bit C2IE_BIT = 0x8C.5
#bit C1IE_BIT = 0x8C.4
#bit LVDIE=0x8c.7
//////////////////////////////////////// PSMC
// Registro di controllo 0
#byte PSMCCON0 = 0x111
#bit SMCCLH = 0x111.7
#bit SMCCLL = 0x111.6
#bit MINDCH = 0x111.5
#bit MINDCL = 0x111.4
#bit MAXDCH = 0x111.3
#bit MAXDCL = 0x111.2
#bit DCH = 0x111.1
#bit DCL = 0x111.0
// Registro di controllo 1
#byte PSMCCON1 = 0x112
#bit SMCON = 0x112.7
#bit S1APOL = 0x112.6
#bit S1BPOL = 0x112.5
#bit NOTUSED = 0x112.4
#bit SCEN = 0x112.3
#bit SMCOM = 0x112.2
#bit PWMPSM = 0x112.1
#bit SMCCS = 0x112.0
//////////////////////////////////////// OP
#byte OPACON = 0x11C
#byte CALCON = 0x110 //
#bit CMPEN=OPACON. 6
#bit OPAON=OPACON. 7
#bit GBWP =OPACON. 0
#bit CAL = CALCON.7
#bit CALREF= CALCON.5
#byte CM1CON0 = 0x119 // comparator 1
#bit C1ON = 0X119.7
#bit C1OUT = 0X119.6
#bit C1OE = 0X119.5
#bit C1POL = 0X119.4
#bit C1SP = 0X119.3
#bit C1R = 0X119.2
#bit C1CHH = 0X119.1
#bit C1CHL = 0X119.0
/////////////////////////////////////// comparator 2
#bit MC2OUT = 0x11b.6
#byte CM2CON0 = 0x11A // comparator 2
#bit C2ON = 0X11A.7
#bit C2OUT = 0X11A.6
#bit C2OE = 0X11A.5
#bit C2POL = 0X11A.4
#bit C2SP = 0X11A.3
#bit C2R = 0X11A.2
#bit C2CHH = 0X11A.1
#bit C2CHL = 0X11A.0
#bit C2IF=0xc.5
////////////////////////////////////// DAC
#byte DAC = 0x11E
#byte DACON0 = 0x11F
#byte ANSEL = 0x9D
#bit DAON= DACON0.7
#bit DAOE= DACON0.6
#bit DARSH= DACON0.1
#bit DARSL= DACON0.0
///////////////////////////////////////////////// Prototipe
short int calibrate_opamp_internal(void) ;
void setup_comparators (void);
void setup_psmc(void);
void setup_dac(void);
void config_mcu(void);
////////////////////////////////////////////////Interrupt
#int_default
void default_isr(void)
if(C2IE_BIT) // Is the interrupt enabled ?
if(C2IF_BIT) // If so, is the interrupt flag set ?
DAC=80; // for debug only
C2IF_BIT = 0; // Clear the interrupt flag
Config_mcu(); //
do
Camp = calibrate_opamp_internal(); // opAMP
while ( !Camp);
setup_dac();
setup_comparators ();
setup_psmc();
Dac =51;
PEIE=1;
C2IE_BIT =1;
do {
delay_ms(1);
} while (1);
void Config_mcu(void)
TRISA=255;
TRISB=37;
WPUB=0;
RBPU=1;
setup_adc_ports( sAN2| sAN3|sAN4| sAN6|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_32);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
setup_timer_1(T1_DISABLED);
C2IE_BIT =0;
C1IE_BIT =0;
LVDIE=0;
PEIE=0;
disable_interrupts(INT_AD);
disable_interrupts(INT_RB);
disable_interrupts(INT_EXT);
disable_interrupts(INT_RTCC);
disable_interrupts(GLOBAL);
void setup_dac()
DARSL=0;
DARSH=0;
DAOE =1;
DAC =0;
DAON =1;
// Configura comparator 1
C1CHH =1; // AN6
C1CHL =0;
C1R =0;
C1POL=0;
C1SP =1;
C1OE =1;
C1ON =1;
// Configura comparator 2
C2CHH =1; // AN6
C2CHL =0;
C2R =0;
C2SP =1;
C2POL=0;
C2OE =0;
C2ON =1; //
SMCON =0 ;
DCH = 0;
DCL = 0;
MAXDCH = 0;
MAXDCL = 0;
MINDCH = 0;
MINDCL = 0;
SMCCLH = 0;
SMCCLL = 0;
SMCCS =1 ;
PWMPSM =1 ;
SMCOM =0 ;
SCEN =0;
S1APOL =0;
S1BPOL =0;
SMCON =1 ;
boolean calibrate_opamp_internal(void)
CMPEN =0;
OPAON =1;
GBWP =0;
CALREF=0;
delay_ms(20);
CAL=1;
while( bit_test(CALCON, 7) );
if (bit_test(CALCON, 6))
return(false);
return(true);
Posted: Thu Feb 24, 2005 2:45 pm |
Quote: | The PC jump always to interrupt vector !
C2IF is cleared. |
If you don't want the PIC to jump to the interrupt vector, then
you need to disable comparator interrupts. For comparator #2,
this is controlled by the C2IE bit. (Not C2IF).
The reason why the comparator #2 interrupt keeps happening
is because the "change" condition has not been cleared. As long
as the "change" condition is set, the PIC will keep setting the C2IF bit,
and if C2IE is also set, then the PIC will jump to your isr.
To clear the "change" condition, you need to read the CM2CON0 register.
You need to add two lines to your default_isr() function, as shown below:
Code: | #int_default
char c; // ADD THIS LINE.
c = CM2CON0; // Clear "change" condition. ADD THIS LINE.
Also, in your main() program, you should read CM2CON0 before you
enable comparator #2 interrupts. Example:
Code: | main()
C2IE_BIT =1;
