Float Division with wrong Answers
SlimG
PostPosted: Thu Feb 24, 2005 6:48 am     Reply with quote
Im trying to do variable divisions with answers between 0 and 360. The problem Im having is that whenever the answer is greater than 255 I don't get the right answer.
(Im using the PIC 16f873)
e.g 7/9*360=280
instead the answer I get is 24
but it works fine with answers under 256
I need the answer to be 280 so that I can display it as a Phase Angle between two sinusoidal waveforms.
bluetooth
PostPosted: Thu Feb 24, 2005 7:34 am     Reply with quote
With:
   a = 7.0;
   b = 9.0;
   c = 360.0;
   d = (a/b) * c;
   sprintf(outbuf,"%f",d);
outbuf has 279.999993 in it.... this is with 3.212 and a 452.
You need to post code, including variable definitions, and state your processor and version number to get help with problems like this. Also, use parens liberally when using CCS!
Idea
PostPosted: Thu Feb 24, 2005 8:18 am     Reply with quote
The division is fine.
The _type_ of your target variable is wrong.
If you are putting this result into an integer, it can only hold 0-255. Hence it 'wraps', and the result given is 280-256 = 24...
