What's this error?
ciccio
What's this error?
PostPosted: Wed Feb 23, 2005 4:39 am     Reply with quote
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "D:\PICC\Ccsc.exe" main.c +FB
No Errors
Halting build on first failed translation as user preferences indicate.
BUILD FAILED: Wed Feb 23 11:38:25 2005
thanks
Humberto
PostPosted: Wed Feb 23, 2005 8:47 am     Reply with quote
1) Are your operating system running from :D ?
2) Try to rename your file with another name different that main.c3) Does the compiler had been running or you are starting with ?
4) Tell us the Compiler version
5) Best wishes Very Happy
Humberto
ciccio
thanks
PostPosted: Wed Feb 23, 2005 9:48 am     Reply with quote
Mplab 6.60 + CCS IDE 3.28, PCB 3.15
I must rename main.c?
Compile with +FB option.
What's:
"Halting build on first failed translation as user preferences indicate."
Is error of MPLAB?
Humberto
PostPosted: Wed Feb 23, 2005 10:22 am     Reply with quote
I ask you 4 questions and you answer only one.
PCB 3.15 does not exist, may be a typo for PCB 3.215.
Anyway I think that your problem is relating the paramaters used
when invoking the compiler from your IDE.
You are using
+FB Select PCB (12 bit)
Add
+EA
Show all error messages and all warnings
Read the Help. You will see all the options in:
Overview/Invoking the Command Line Compiler
Hope this help.
Humberto
Humberto
PostPosted: Wed Feb 23, 2005 10:23 am     Reply with quote
You are using
Add
+EA
Hope this help.
Humberto
Mark
PostPosted: Wed Feb 23, 2005 5:28 pm     Reply with quote
Easy, you are using the wrong tool suite. You can not use the CCS Compiler entry. You must pick the one listed with PIC12/PIC16/PIC18 - something like that. I am too lazy to start MPLAB and look Very Happy
