PORTt E, pin E0 when set to high cant output onto PORT D
flip
PostPosted: Wed Feb 23, 2005 12:32 pm     Reply with quote
For some reason when I set pin E0 to high and in a if statement (bit_test (input_e(), 0) == 1 ), then output on to Port D, Port D does not get displayed. However once I get out of the if statement the port D value outputs for a second. As well in the if statement all of the other ports output fine, even Port D. Except when I set E0 to high. I am guessing I am setting a fuse incorrectly but if you can figure it out that would be great. Thanks
#include <18F458.h>     //up/down counter with 1 7 segment displays no max or min
#use delay(clock=20000000)    //check to see if casting works
#fuses HS, NOWDT,OSCSEN, BROWNOUT, BORV20, STVREN, NODEBUG, NOLVP
      set_tris_e(0x00);
      set_tris_c(0xFF);                          //hundreds display
      set_tris_b(0xFF);
   set_tris_d(0xFF);                  //tens display
    if(bit_test(input_e(), 1) == 1)      //E1 = 1
      output_b(0xFF);            //All of the Ports output even D
       output_d(0xFF);
       output_c(0xFF);
       output_d(0x00);
       output_b(0x00);
       output_c(0x00);
    if(bit_test(input_e(), 0) == 1)   // set E0 to 1 and it goes into the loop
      output_b(0x0F);
       output_d(0x0F);   //Port D does not display,but  Port C and B do display
       output_c(0x0F);
       output_d(0x00);
       output_b(0x00);
       output_c(0x00);
drh
PostPosted: Wed Feb 23, 2005 12:44 pm     Reply with quote
Use this instead:
if ((input(PIN_E1) == 1)
if ((input(PIN_E0) == 1)
David
