ccs@jeffmann.endjunk.com Guest
using Make16() on signed variables |
Posted: Tue Feb 22, 2005 9:39 pm |
I do not understnad if I can use make16() to combine two 8 bit nibbles into a signed 16 bit int16.
the manual explains make16() as doing:
Code: | i16 = (int16)(varhigh&0xff)*0x100+(varlow&0xff) |
so, I am concerned that I cannot do:
[/code]
unsigned int8 byte1, byte2;
signed int16 origional, final;
byte1=make8(origional,1);
byte2=make8(origional,0);
final=make16(byte1, byte2);
[code]
does the signing cause a problem in this case? |
bluetooth
Posted: Tue Feb 22, 2005 10:21 pm |
Since it's simple, I tried it....
The following:
origional = -23456;
Results in byte1 = 0xA4 and byte 2 = 0x60, and final = original = 0xa460.
So, with 3.212 on a 452 it works fine....
Bytes is bytes.... ![Wink](images/smiles/icon_wink.gif) |
