active toolsuites in mplab
jess
PostPosted: Sun Feb 20, 2005 1:34 am     Reply with quote
i'm currently using CCS with mplab. whats the difference between 'ccs c compiler' and 'ccs c compiler for pic 12/14/16/18' in the active toolsuite menu in project wizard in mplab? i'm using pic16f877a. when i select the 2nd option and run the program i get lots of errors such as 'expecting a declaration'. with the 1st option i get this error:
Error[99] C:\proj\a.c 5 : Option invalid Not a valid port: B
although i'm sure there's nothing wrong with that line. thanks!
Mark
PostPosted: Sun Feb 20, 2005 9:14 am     Reply with quote
ccs c compiler - is an older "Legacy" tool suite. It should not be use. It will not work correctly for you.
'ccs c compiler for pic 12/14/16/18' - is the right one.
You problem: Most likely your code. But we can't tell since you did post any.
