What is wrong?: "subscript out of range"
PostPosted: Fri Feb 18, 2005 11:11 am     Reply with quote
Hi, I don't know why this will not compile. It gives an error of "subscript out of range" for fs[7].What's the problem with this code?
#include <18F458.h>
#device ADC=8   //set for 8 bit A/D
#use delay(clock=20000000)   //40Mhz
#fuses HS, OSCSEN, BROWNOUT, BORV20, STVREN, NODEBUG, NOLVP //High Speed, Oscillator switching enabled, Brownout reset at 2.0V, Stack full causes rest, Low Voltage programming
float fs[7];
unsigned int16 q=440;
   fs[0] = (440/q)*2439;      //Octave 0
   fs[1] = (440/q)*1220;      //Octave 1
   fs[2] = (440/q)*610;         //etc.
   fs[3] = (440/q)*305;
   fs[4] = (440/q)*152;
   fs[5] = (440/q)*76;
   fs[6] = (440/q)*38;
   fs[7] = (440/q)*19;
[/code]
libor
PostPosted: Fri Feb 18, 2005 11:16 am     Reply with quote
Try it with the following declaration
float fs[8];
PostPosted: Fri Feb 18, 2005 11:25 am     Reply with quote
Yeah I tried that with that little test program, but here is my real program and it has the same problem. Could it have to do with running out of RAM? Please try to compile this code and see whats wrong. Thanks
//Control Program
#include <18F458.h>
#use delay(clock=40000000)   //40Mhz
//Calibration variables
unsigned int j = 0;     //ones place
unsigned int k = 4;     //tens place
unsigned int m = 4;     //hundreds place
unsigned int r = 0;
unsigned int16 q =440;
//Tuning mode variables
unsigned int16 i = 0;
unsigned int16 i2 = 0;
unsigned int sig[1300];   //array for signal data
unsigned int test=0;      //To test if input is above voltage threshold
unsigned int16 freq=0;      //Global variable for the frequency of the incoming signal
unsigned int16 peaks=0;   //Global vairables for number of peaks counted
int default_note = 0;   //Global variable to keep the value of the note to be displayed after tuning
int default_octive = 0; //Global variable to keep the value of the note to be displayed after tuning
unsigned int16 fs[7];
float Ts[7];
unsigned int x;
int convert(int n)
   if(n==0)
     return 0b00111111;
   if(n==1)
     return 0b00000110;
   if(n==2)
     return 0b01011011;
   if(n==3)
     return 0b01001111;
   if(n==4)
     return 0b01100110;
   if(n==5)
     return 0b01101101;
   if(n==6)
     return 0b01111101;
   if(n==7)
     return 0b00000111;
   if(n==8)
     return 0b01111111;
   if(n==9)
     return 0b01100111;
int display_note(int n)
   if(n==0) //A
      return 0b01110111;
   if(n==1) //A#
      return 0b11110111;
   if(n==2) //B
      return 0b01111100;
   if(n==3) //C
      return 0b00111001;
   if(n==4) //C#
      return 0b10111001;
   if(n==5) //D
      return 0b01011110;
   if(n==6) //D#
      return 0b11011110;
   if(n==7) //E
      return 0b01111001;
   if(n==8) //F
      return 0b01110001;
   if(n==9) //F#
      return 0b11110001;
   if(n==10) //G
      return 0b01101111;
   if(n==11) //G#
      return 0b11101111;
void count_up(void)
   if(j <= 8)
      j=j+1;
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
      j=0;
      r = convert(j);
      output_d(r);
      if(k <= 8)
         k=k+1;
         //r = convert(k);
         output_a(k);
         //r = convert(m);
         output_c(m);
         k=0;
         //r = convert(k);
         output_a(k);
         m=m+1;
         //r = convert(m);
         output_c(m);
void count_down(void)
   if(j >= 1)
      j=j-1;
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
      j=9;
      r = convert(j);
      output_d(r);
      if(k >= 1)
         k=k-1;
         //r = convert(k);
         output_a(k);
         //r = convert(m);
         output_c(m);
         k=9;
         //r = convert(k);
         output_a(k);
         m=m-1;
         //r = convert(m);
         output_c(m);
void get_freq(void)
   peaks=0;   //reset previous values
   for(i=0;i<1296;i++)
         i2=i+2;
         if(sig[i2]>=sig[i2-1] && sig[i2]>=sig[i2-2] && sig[i2]>=sig[i2+1] && sig[i2]>=sig[i2+2])
            peaks=peaks+1;   //Tests to see if current sample is greater that the 2 before and after
   freq = peaks/Ts[x];      //Frequency of the signal
void look_up(float u, int16 v)     // u = concert A, v = freq
   float H;
   float G;
   unsigned int octive = 0;
   unsigned int note = 0;
   unsigned int r;
   unsigned int s;
   unsigned int i = 0;
   G = u / 16;
   u = u / 16;
   while(G <= v)
      G = G * 2;
      octive = octive+1;
   octive = octive - 1;
    s = 1;
   while(s <= octive)
      u = u * 2;
      s = s+1;
   for ( i = 0; u < v; i++)
      u = u * 1.0297F;
   H = u/v;
     if(bit_test(i, 0) == 1)   //odd and that it is high
      note = (i-1)/2;
      output_e(0x04);      //to high
   if(bit_test(i, 0) == 0)   //even and that it is too low
      note = i/2;
      if(H  < 1.020000000000000F)
         output_e(0x02);   //exact
         output_e(0x01);   //to low
   if(note == 12)
      octive = octive +1;
      note = 0;
   //r = convert(octive);
   //output_d(r);
   output_c(octive);  //Wire up PORT C to LEDs for know and it will display octive in binary
   default_note = note;   //A global variable to keep the value of the note while finished tuning
   default_octive = octive;
   r = display_note(note);
   output_d(r);      //Wire up PORT D to 7 - segment display and it will display the note
void calib_m()    //Frequency determination mode
   set_tris_a(0xFF);                         //tens display
   set_tris_d(0xFF);                         //ones display
   set_tris_c(0xFF);                         //hundreds display
   set_tris_b(0x00);
   set_tris_e(0x00);
   r = convert(7);      //S
   output_d(r);
   r = display_note(7);    //E
   output_a(r);
   r = convert(5);      //T
   output_c(r);
   delay_ms(10000);     //Set
   r = display_note(0);
   output_d(r);
   delay_ms(10000);     //A
   //r = convert(j);
   output_d(j);
   //r = convert(k);
   output_a(k);
   //r = convert(m);      //Show last setting of Concert A
   output_c(m);
   q = (int16)m*100 + (int16)k*10 + (int16)j;      //q is the decimal representation on the 7-segment display
   while(bit_test(input_e(), 0) == 1)           //not set, switch out of calibration mode
     if(bit_test(input_b(), 5) == 1)           //reset
         j=0;
         k=4;
         m=4;
      if((341 <= q ) && (q <= 539))
         if(bit_test(input_b(), 3) == 1)
            count_up();
         if(bit_test(input_b(), 2) == 1)
            count_down();
      if(q == 340)      //Cant go below 340Hz
            count_up();
      if(q == 540)      //Cant go above 540Hz
            count_down();
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
   r = convert(j);
   output_d(r);
   //r = convert(k);
   output_a(k);
   //r = convert(m);
   output_c(m);
void tunning_m()
   float fs[6];
   float Ts[6];
   unsigned int x= 0;
   //set_tris_a(0xF0);
   set_tris_d(0xFF);      //Wire up PORT D to 7 - segment display and it will display the note
   set_tris_c(0xFF);      //Wire up PORT C to LEDs for know and it will display octive in binary
   set_tris_b(0x00);
   set_tris_e(0xFF);
   enable_interrupts(INT_AD);
   enable_interrupts(global);
   setup_adc_ports(RA0_ANALOG);   //Set A0 for analog input
   setup_adc(ADC_CLOCK_DIV_32);   //clock frequency
   set_adc_channel(0);   //Use PORT A0 to read incoming signal
   fs[5] = (440/q)*76;
   fs[6] = (440/q)*38;
   fs[7] = (440/q)*19;
   for (x =0; x <= 7; x++)
      Ts[x] = fs[x] * 2 * 1300;
   //x = x - 1;         We may have to adjust if x = 8;
   while(bit_test(input_e(),  1) == 1)
      if(bit_test(input_b(), x) == 0)
         for (x = 0; x <= 7; x ++)
            if(bit_test(input_b(), x) == 1)
                  test = 0;   //initialize test
                 test = read_adc();
               if(test>=170)    //Wait until input signal is above certain threshold (So noise isn't "tuned")
                 output_a(0b00100000);   //"Tuning" (green)
                 for(i=0; i<1300 ;i++)      //take 1300 samples (.325 seconds worth))
                   sig[i] = read_adc();
                   delay_us(fs[x]);      //4kHz sampling frequency
                 get_freq();   //obtain frequency of digital signal
                 look_up(q,freq);   //Display the note of the signal
                  output_a(0b00010000);   //Output "ready" light (yellow)
                  freq=0;               //reset frequency
                  r = display_note(default_note);      //Display last note tuned
                  //output_c(r);
                  output_d(r);
                  r = convert(default_octive);        //Display last octive tuned
                  //output_d(r);
                  output_d(r);
           test = read_adc();
              //output_c(r);
              output_d(r);
              //output_d(r);
              output_d(r);
void tone_gen_m()
   while(bit_test(input_e(),  2) == 1)
      if(bit_test(input_e(), 0) == 1)
         calib_m();
      if(bit_test(input_e(),  1) == 1)
         tunning_m();
      if(bit_test(input_e(),  2) == 1)
         tone_gen_m();
Mark
This isn't VB Very Happy
PostPosted: Fri Feb 18, 2005 11:30 am     Reply with quote
//Control Program
#include <18F458.h>
unsigned int r = 0;
float Ts[7];
unsigned int x;
int convert(int n)
   if(n==0)
     return 0b00111111;
   if(n==1)
     return 0b00000110;
   if(n==2)
     return 0b01011011;
   if(n==3)
     return 0b01001111;
   if(n==4)
     return 0b01100110;
   if(n==5)
     return 0b01101101;
   if(n==6)
     return 0b01111101;
   if(n==7)
     return 0b00000111;
   if(n==8)
     return 0b01111111;
   if(n==9)
     return 0b01100111;
   if(n==0) //A
      return 0b01110111;
   if(n==1) //A#
      return 0b11110111;
   if(n==2) //B
      return 0b01111100;
   if(n==3) //C
      return 0b00111001;
   if(n==4) //C#
      return 0b10111001;
   if(n==5) //D
      return 0b01011110;
   if(n==6) //D#
      return 0b11011110;
   if(n==7) //E
      return 0b01111001;
   if(n==8) //F
      return 0b01110001;
   if(n==9) //F#
      return 0b11110001;
   if(n==10) //G
      return 0b01101111;
   if(n==11) //G#
      return 0b11101111;
void count_up(void)
   if(j <= 8)
      j=j+1;
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
      j=0;
      r = convert(j);
      output_d(r);
      if(k <= 8)
         k=k+1;
         //r = convert(k);
         output_a(k);
         //r = convert(m);
         output_c(m);
         k=0;
         //r = convert(k);
         output_a(k);
         m=m+1;
         //r = convert(m);
         output_c(m);
   if(j >= 1)
      j=j-1;
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
      j=9;
      r = convert(j);
      output_d(r);
      if(k >= 1)
         k=k-1;
         //r = convert(k);
         output_a(k);
         //r = convert(m);
         output_c(m);
         k=9;
         //r = convert(k);
         output_a(k);
         m=m-1;
         //r = convert(m);
         output_c(m);
void get_freq(void)
   for(i=0;i<1296;i++)
         i2=i+2;
   float H;
   float G;
   unsigned int r;
   unsigned int s;
   unsigned int i = 0;
   G = u / 16;
   u = u / 16;
   while(G <= v)
      G = G * 2;
      octive = octive+1;
    s = 1;
   while(s <= octive)
      u = u * 2;
      s = s+1;
      u = u * 1.0297F;
   H = u/v;
      note = (i-1)/2;
      note = i/2;
   if(note == 12)
      octive = octive +1;
      note = 0;
   //output_d(r);
   set_tris_b(0x00);
   set_tris_e(0x00);
   r = convert(7);      //S
   output_d(r);
   output_a(r);
   r = convert(5);      //T
   output_c(r);
   output_d(r);
   //r = convert(j);
   output_d(j);
   //r = convert(k);
   output_a(k);
   output_c(m);
         j=0;
         k=4;
         m=4;
            count_up();
            count_down();
            count_up();
            count_down();
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
   r = convert(j);
   output_d(r);
   //r = convert(k);
   output_a(k);
   //r = convert(m);
   output_c(m);
void tunning_m()
   float fs[6];
   float Ts[6];
   unsigned int x= 0;
   //set_tris_a(0xF0);
   set_tris_b(0x00);
   set_tris_e(0xFF);
   fs[5] = (440/q)*76;
   fs[6] = (440/q)*38;
   fs[7] = (440/q)*19;
                 test = read_adc();
                  //output_c(r);
                  output_d(r);
                  //output_d(r);
                  output_d(r);
           test = read_adc();
              //output_c(r);
              output_d(r);
              //output_d(r);
              output_d(r);
void tone_gen_m()
         calib_m();
         tunning_m();
         tone_gen_m();
libor
PostPosted: Fri Feb 18, 2005 11:36 am     Reply with quote
In your real program you got even further from the solution declaring the array of another element less : [6] Laughing
PostPosted: Fri Feb 18, 2005 11:48 am     Reply with quote
//Control Program
#include <18F458.h>
unsigned int r = 0;
float Ts[7];
unsigned int x;
int convert(int n)
   if(n==0)
     return 0b00111111;
   if(n==1)
     return 0b00000110;
   if(n==2)
     return 0b01011011;
   if(n==3)
     return 0b01001111;
   if(n==4)
     return 0b01100110;
   if(n==5)
     return 0b01101101;
   if(n==6)
     return 0b01111101;
   if(n==7)
     return 0b00000111;
   if(n==8)
     return 0b01111111;
   if(n==9)
     return 0b01100111;
   if(n==0) //A
      return 0b01110111;
   if(n==1) //A#
      return 0b11110111;
   if(n==2) //B
      return 0b01111100;
   if(n==3) //C
      return 0b00111001;
   if(n==4) //C#
      return 0b10111001;
   if(n==5) //D
      return 0b01011110;
   if(n==6) //D#
      return 0b11011110;
   if(n==7) //E
      return 0b01111001;
   if(n==8) //F
      return 0b01110001;
   if(n==9) //F#
      return 0b11110001;
   if(n==10) //G
      return 0b01101111;
   if(n==11) //G#
      return 0b11101111;
void count_up(void)
   if(j <= 8)
      j=j+1;
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
      j=0;
      r = convert(j);
      output_d(r);
      if(k <= 8)
         k=k+1;
         //r = convert(k);
         output_a(k);
         //r = convert(m);
         output_c(m);
         k=0;
         //r = convert(k);
         output_a(k);
         m=m+1;
         //r = convert(m);
         output_c(m);
   if(j >= 1)
      j=j-1;
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
      j=9;
      r = convert(j);
      output_d(r);
      if(k >= 1)
         k=k-1;
         //r = convert(k);
         output_a(k);
         //r = convert(m);
         output_c(m);
         k=9;
         //r = convert(k);
         output_a(k);
         m=m-1;
         //r = convert(m);
         output_c(m);
void get_freq(void)
   for(i=0;i<1296;i++)
         i2=i+2;
   float H;
   float G;
   unsigned int r;
   unsigned int s;
   unsigned int i = 0;
   G = u / 16;
   u = u / 16;
   while(G <= v)
      G = G * 2;
      octive = octive+1;
    s = 1;
   while(s <= octive)
      u = u * 2;
      s = s+1;
      u = u * 1.0297F;
   H = u/v;
      note = (i-1)/2;
      note = i/2;
   if(note == 12)
      octive = octive +1;
      note = 0;
   //output_d(r);
   set_tris_b(0x00);
   set_tris_e(0x00);
   r = convert(7);      //S
   output_d(r);
   output_a(r);
   r = convert(5);      //T
   output_c(r);
   output_d(r);
   //r = convert(j);
   output_d(j);
   //r = convert(k);
   output_a(k);
   output_c(m);
         j=0;
         k=4;
         m=4;
            count_up();
            count_down();
            count_up();
            count_down();
      r = convert(j);
      output_d(r);
      //r = convert(k);
      output_a(k);
      //r = convert(m);
      output_c(m);
   r = convert(j);
   output_d(r);
   //r = convert(k);
   output_a(k);
   //r = convert(m);
   output_c(m);
void tunning_m()
   float fs[6];
   float Ts[6];
   unsigned int x= 0;
   //set_tris_a(0xF0);
   set_tris_b(0x00);
   set_tris_e(0xFF);
   fs[5] = (440/q)*76;
   fs[6] = (440/q)*38;
   fs[7] = (440/q)*19;
                 test = read_adc();
                  //output_c(r);
                  output_d(r);
                  //output_d(r);
                  output_d(r);
           test = read_adc();
              //output_c(r);
              output_d(r);
              //output_d(r);
              output_d(r);
void tone_gen_m()
         calib_m();
         tunning_m();
         tone_gen_m();
PostPosted: Fri Feb 18, 2005 12:02 pm     Reply with quote
never mind, I found the error. There was the same local variables initialized wrong in the subroutine.... sorry
Hans Wedemeyer
PostPosted: Sat Feb 19, 2005 4:34 pm     Reply with quote
You may have an error in your subroutine (arrrrrrrgh VB known as functions in C !) however Libor told you where the Subscript of of range error comes from...
Remember this is C not cobol...
You delcared
declares there are SEVEN locations in the fs array,
elsewhere in your code you use index fs[7] which is trying to access index 8 in the array.... you do not have 8 locations when you declare fs[7]....
0-6 is a count of 7
0-7 = a count of 8
PostPosted: Sun Feb 20, 2005 4:32 am     Reply with quote
There are many more errors, after browsing the source for two minutes I stopped because I found the following list:
1) Global variables never used (and worse, have same name as local variables):
float Ts[7];
2) Arrays declared too small. Except for the affore mentioned 'float Ts[6]', there is the same problem with 'float Ts[6]'.
3) An offset error in bit_test:
          another for-loop with x
This needs some serious rework:
- The for-loop will exit with x == 8. The bit_test will give strange results when you are trying to test bit 8 (7 is the maximum allowed).
- The line for corrrecting x is in the wrong place, later in the source x is modified again.
- The for-loops will always exit with x being 8 (or 7 after correction). So, if it is always the same value, then it doesn't make sense to pass x as a variable to the bit_test(). Very likely you wanted some other behaviour here.
PostPosted: Sun Feb 20, 2005 4:35 am     Reply with quote
float Ts[7];
2) Arrays declared too small. Except for the affore mentioned 'float fs[6]', there is the same problem with 'float Ts[6]'.
