Using PORT A while also using ADC
flip
PostPosted: Fri Feb 18, 2005 10:40 am     Reply with quote
Hi, I'm using the ADC on port A0, and I also want to output on the other bits of port A. Is this possible? I notice if I set tris A to anything, then it will screw up the ADC. Thanks
Mark
PostPosted: Fri Feb 18, 2005 10:53 am     Reply with quote
Read the datasheet. Look under the Analog to Digital convertor section. It will show you what combination of Analog and Digital you can have. You didn't specify what pic but for the ones that I know, yes you can.
PostPosted: Fri Feb 18, 2005 11:05 am     Reply with quote
yeah thanks, I'm, using the 18f458
