what is Best coding?
Posted: Fri Feb 18, 2005 4:11 am
Dear Master.
Someone use
#bit A0 = porta.0
#define ON 1
if(A0 == ON)
another one use
if(input(pin_a0))
what is best code? _________________ Hello~?
This is South KOREA
My name is Sanghyouk Kim But Call me Nick
Sorry I'm poor English
EdWaugh
Joined: 07 Dec 2004 Posts: 127 Location: Southampton, UK
hi again
Posted: Fri Feb 18, 2005 5:04 am
both look alright to me but if your using the CCS compiler I would use:
if(input(pin_a0));
you don't need to redefine a bit to represent pin_a0 because its already done just use pin_a0 to mean that pin. You also don't ned to do a comparison because the pin evaluates to 1 or 0 ie True or False which is already the result your looking for in an if() statement. I think the CCS manual talks about this somewhere try and look in that. I think my code might compile more efficient as well.
