Winpenny RS485 Source Code Question
lguancho
PostPosted: Fri Feb 18, 2005 2:59 am     Reply with quote
Hi, all. I am trying to port and test Winpenny's RS485 code from Pic16F to Pic18F452. I redefine the register addresses (PORTX, TRISX etc) in the header file. The code could be compiled, and I am trying to test it in with a chip, sending some command string to my PC (turn on the serial port monitor in CCS IDE). I keep receiving a series of '0' , instead of some "Hello" string.
I find that the problem lies with the setup() and configurecom() function. When I disables these functions, and use CCS #use Rs232() fuction, I can receive without any problem.
Could anyone help to see what I have done wrong on the setup() and configurecom()
[code]
#define MASTER
#include <18F452.h>
#fuses HS,NOLVP,NOWDT,PUT
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,errors, enable=PIN_C5)
#include "D:\rs485net\Include\reg18F452.h"
#include "D:\rs485net\Include\rs485.h"
#include <stdlib.h>
#include "D:\rs485net\Include\lcd873b.h"
#include "D:\rs485net\lcd873b.c" // Keypad LCD routine
#include "D:\rs485net\Rs485.c" // RS485 protocol driver
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
char cTest[10];
// Timer Interrupt service routine
#INT_RTCC
clock_isr()
TMR0L = TMR0_RELOAD; // Reload PICs timer
BIT_CLEAR( INTCON, TMR0IF ); // Clear interrupt flag
// USART interrupt service routine
#INT_RDA
void UsartInterrupt(void)
while ( BIT_TEST( PIR1, RCIF ) ) // If USART RX Interrupt
TMR0L = TMR0_RELOAD; //TMR0_RELOAD
cRs485RxChar = getc(); //RCREG;
if ( !( RCSTA & 6 ) ) // Then if no errors
{ // Process received character
Rs485Decode(); // Decode RS485 network trafic
bit_set( RCSTA, CREN ); // Enable receiver.
bit_clear( RCSTA, CREN ); // Clear any errors
cRs485RxChar = getc(); // =RCREG
bit_clear( PIR1, RCIF );
char cPacketReady;
char cLenOfData;
char cCmd, c;
//Setup(); // Enable interrupts
//BIT_CLEAR( INTCON, TMR0IE ); // Timer interrupts off
#ifndef MASTER
LcdWrite("Waiting........");
#else
LcdWrite("Sending message");
// Just setup the network address
//write_eeprom( NET_ADDRESS_HIGH, 0x10 );
//write_eeprom( NET_ADDRESS_LOW, 0x10 );
//cOurAddrHigh = read_eeprom( NET_ADDRESS_HIGH );
//cOurAddressLow = read_eeprom( NET_ADDRESS_LOW );
while ( 1 )
cOurAddrHigh = 'A'; //0x10;
cOurAddrLow = 'A'; //0x10;
Rs485Initialise( cOurAddrHigh,cOurAddrLow );
#ifdef MASTER
cTest[0] = 'H';
cTest[1] = 'e';
cTest[2] = 'l';
cTest[3] = 'l';
cTest[4] = 'o';
cTest[5] = 13;
ClearLine2();
LcdWrite("GET DATA PKT");
Rs485SendPacket( SENSOR_GET_DATA, 5, &cTest[0] );
delay_ms(2500);
delay_ms(2500);
delay_ms(2500);
delay_ms(2500);
ClearLine2();
LcdWrite("POLL PKT");
Rs485SendPacket( SENSOR_POLL_CMD, 0, &cTest[0] );
delay_ms(2500);
delay_ms(2500);
delay_ms(2500);
delay_ms(2500);
cOurAddrHigh = 0x10;
cOurAddrLow = 0x18;
// Send a packet to another node
delay_ms(250);
delay_ms(250);
delay_ms(250);
delay_ms(250);
cPacketReady = Rs485Process();
if ( cPacketReady )
Rs485GetPacket( &cCmd, &cLenOfData, &cTest[0] );
delay_ms(10000);
Rs485SendPacket(cCmd, cLenOfData, &cTest[0] );
ClearLine2();
LcdWrite( "CMD: " );
BinToHexAscii( cCmd );
LcdWrite( ' ' );
if ( cLenOfData != 0 )
for ( c=0; c<cLenOfData; c++ ) LcdWrite( cTest[c] );
//Rs485SendPacket( SENSOR_ACK, 0, NULL );
delay_ms(255);
Rs485Initialise(cOurAddrHigh,cOurAddrLow);
ClearLine1();
// Setup Hardware
void Setup(void)
T0CON = 0xC4; // 8Bit TMR0 prescal = enable, rate = 1:32
INTCON = 0; // disable global interupts
// ADCON1 = 0x07; // Disable ADC
TRISA = PortAConfig; // 0b00111111 for slave
TRISB = PortBConfig; // 0b00000000 for slave
TRISC = PortCConfig; // 0b00000000
TRISD = PortDConfig;
TRISE = PortEConfig;
//PORTC = 0xFF;
LCDSetup(); // Setup the LCD Display
//ConfigureComms(); /* Configure USART for Asyncronous Comms */
//BIT_SET(INTCON,GIE);
//* Configure PIC18F452 USART for communications */
//* Asynchronous mode */
//* 8 data bits ( For other rates see PIC16F8XX Data ) */
//* 1 stop bits */
//* No Parity */
void ConfigureComms(void)
// SPBRG = 64; // Set Baud rate 19,200 20MHz clock
SPBRG = 129; // 9600 Baud at 20MHz
BIT_CLEAR( TXSTA, TX9 ); // 8 bit transmit mode
BIT_SET( TXSTA, BRGH ); // BRGH = 1 High speed mode- Note smaller baud rate error%
BIT_CLEAR( TXSTA, SYNC ); // Asyncronous mode;
BIT_SET( TXSTA, TXEN ); // Enable Transmitter
PIR1 = 0x00; // Clear all interrupt flags including AUSART TX & RX
BIT_SET( PIE1,TXIE ); // Enable Transmit Interrupts
BIT_SET( PIE1,RCIE ); // Enable Receive Interrupts
BIT_SET( INTCON, PEIE ); // Enable all Peripheral Interrupts
BIT_SET( RCSTA, CREN ); // Enable continuous receive
BIT_CLEAR( RCSTA, RX9 ); // 8 bit receive mode
BIT_SET( RCSTA, SPEN ); // Enable Serial port
[/code]
Question 2: Inside the serial rx ISR, the TMR0 is loaded with a value of 255 (defined by TMR0_Reload). I don't understand this? Could someone help to explain the purposes of this timer function within the rx ISR?
Warmest Regards
lguancho
Mark
PostPosted: Fri Feb 18, 2005 8:45 am     Reply with quote
My guess would be that you didn't redefine all the register addresses correctly. You didn't post them so we don't really know. This would include the UART setup registers.
