pfaerber Guest
pic12CE673 and EEProm |
Posted: Tue Apr 15, 2003 8:08 am |
I try to use the internal EEProm. But I became the error
Error[100] g:\pic\kammer1\ce67x.c 33 : USE parameter value is out of range Not a number: =46
the USE line is
#ifndef EEPROM_SDA
#define PIN_A6 = 46 //these are not in the 12ce67x.h file
#define EEPROM_SDA PIN_A6
#endif
#ifndef EEPROM_SCL
#define PIN_A7 = 47 //these are not in the 12ce67x.h file
#define EEPROM_SCL PIN_A7
#endif
#use i2c(MASTER, SDA=EEPROM_SDA, SCL=EEPROM_SCL, NO_STRETCH, NOFLOAT_HIGH)
I can understand.
Is it the right way to use the EEProm. Or is there a better way ?
Paul
Sorry for the bad English I am German
___________________________
Original Post ID: 13682 |
pfaerber Guest
Re: pic12CE673 and EEProm |
Posted: Tue Apr 15, 2003 8:15 am |
Sorry I have seen the error
#define PIN_A6 = 46
better :-)
#define PIN_A6 46
By
Original Post ID: 13683 |
somy Guest
Posted: Fri Jan 13, 2006 12:43 am |
pfaerber wrote: | I try to use the internal EEProm. But I became the error
the USE line is
#ifndef EEPROM_SDA
#endif
#ifndef EEPROM_SCL
#endif
I can understand.
Paul
