doubt
guest
doubt
PostPosted: Tue Feb 15, 2005 4:09 pm     Reply with quote
Hi everyone,
I have a small doubt. I am enabling a timer in PIC that interrupts every 15ms. I have a subroutine, that has a delay statement with delay of 20ms. I would like to know, whether timer interrupts in between the delay statements or not. I believe that delay statements are just NOP commands in Assembly and timer would interrupt in between them, if it overflows. Please post any comments and corrections if I am wrong.
sk
flip
doubt
PostPosted: Tue Feb 15, 2005 4:16 pm     Reply with quote
Yes. the timer interrupts when the program is in the delay subroutine.
PostPosted: Tue Feb 15, 2005 4:32 pm     Reply with quote
The interrupt flag is set, but the interrupt may not be serviced
immediately in certain cases.
See these threads for the reason why:
http://www.ccsinfo.com/forum/viewtopic.php?t=20704
http://www.ccsinfo.com/forum/viewtopic.php?t=21367
Also see this thread which discusses it more,
and provides a link to Darren Rook's FAQ article
with a work-around solution.
http://www.ccsinfo.com/forum/viewtopic.php?t=18356
flip
Timer0 interrupt
PostPosted: Tue Feb 15, 2005 5:21 pm     Reply with quote
I cant get my timer0 interrupt to work do you know what the problem is ?
#include <18F458.h>     //up/down counter with 3 7 segment displays no max or min
#fuses HS, OSCSEN, BROWNOUT, BORV20, STVREN, DEBUG, LVP
int t = 0;
#int_TIMER0 // interrupt occurs every 3.2micro sec * 256 = 819.12 micro seconds
TIMER0_isr()
   if (t++ == 244)   // After t gets up to 2441 , 2 seconds has lapsed 819.12 micro seconds * 2442 = 2 seconds
      t = 0;
      output_c(0x03);  // output a light every 2 seconds
   set_tris_d(0xFF);
   set_tris_a(0xFF);
   set_tris_b(0xFF);
   set_tris_c(0xFF);
   set_tris_e(0xFF);
   setup_counters(RTCC_INTERNAL, RTCC_DIV_32); //pulse occurs every 3.2 micro seconds (1/(40MHz/4*32))
   enable_interrupts(global);
    output_c(0x01);
flip
Timer0 interrupt
PostPosted: Tue Feb 15, 2005 5:22 pm     Reply with quote
int t = 0;
TIMER0_isr()
      t = 0;
   set_tris_d(0xFF);
   set_tris_a(0xFF);
   set_tris_b(0xFF);
   set_tris_c(0xFF);
   set_tris_e(0xFF);
    output_c(0x01);
Mark
PostPosted: Tue Feb 15, 2005 9:11 pm     Reply with quote
Rember that any function you call from an isr and from the main program will have interrupts disabled. This includes the delay_ms() routine.
bluetooth
PostPosted: Wed Feb 16, 2005 8:19 am     Reply with quote
Even though fast_io is not specified, I wonder why all the TRIS's are being set to 0xff - makes generating an output really tough....
Microchip DDR = ~Motorola DDR!
My $0.02....
