can't get 10f206 to do any thing....argh
john bougs
PostPosted: Fri Feb 11, 2005 3:01 pm     Reply with quote
I cant seem to get any code to run on a 10f206
Version of your compiler: 3.217
Target PIC Microcontroller PIC10F206 @ 5V
I have given up on my code and tried the EX_TGETC.C example. the only lines I have changed are
#if defined(__PCB__)
#include <10f206.h>
#fuses NOMCLR, NOWDT,NOPROTECT
#use rs232(baud=9600, xmit=PIN_B0, rcv=PIN_B1)
but the processor will not run. I have verified the the device is programming. (an read back / verify the code) any ideas what i am doing wrong?
////                         EX_TGETC.C                              ////
////  This program echoes the key presses of the user and times-     ////
////  out after a specified amount of time.                          ////
////  Configure the CCS prototype card as described below.           ////
////  This example will work with the PCB, PCM and PCH compilers.    ////
////  The following conditional compilation lines are used to        ////
////  include a valid device for each compiler.  Change the device,  ////
////  clock and RS232 pins for your hardware if needed.              ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#include <10f206.h>
#elif defined(__PCM__)
#include <16F877.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)  // Jumpers: 8 to 11, 7 to 12
#elif defined(__PCH__)
#include <18F452.h>
#include <input.c>
#define  KEYHIT_DELAY   500     // in milliseconds
char timed_getc() {
   long timeout;
   char retval;
   timeout=0;
   while(!kbhit() && (++timeout< (KEYHIT_DELAY*100)))
      delay_us(10);
   if(kbhit())
      retval = getc();
      retval = 0;
   return(retval);
   int status;
   char value;
      status=1;
      printf("\r\nStart typing:\r\n");
      while(!kbhit());
      while(status==1)
         value=timed_getc();
         if(value==0)
            status=0;
            status=1;
            putc(value);
      printf("\r\nToo slow!\r\n");
PostPosted: Fri Feb 11, 2005 5:26 pm     Reply with quote
The comparator in the 10F206 is turned on by default, at power-up.
CCS may not turn it off in their startup code. I don't have
the PCW compiler, so I can't test that for you.
If they don't turn it off, the next step would be to use the CCS
setup_comparator() function to do that. Example:
You may want to check the 10F206.H file, and see if NC_NC_NC_NC is
the proper constant that CCS uses to turn off the comparator for
the 10F206.
If that function doesn't work, then you can do it manually with code
by defining the address of the CMCON0 register, and then writing
the appropriate value to it. Example:
#include <10F206.h>
#byte CMCON0 = 0x07      // Define the address of CMCON0
CMCON0 = 0xF7;  // Turn off the comparator (Set CMPON = 0)
printf("Hello World");
while(1);   // Prevent PIC from going to sleep
theMagni
Two things
PostPosted: Fri Feb 11, 2005 5:59 pm     Reply with quote
There are two issues using the 10F series with CCS. First, you'll have to use a touch of assembly to get the tristates to work correctly. I wasn't able to set the tristating any other way, despite the documentation.
Use this:
  //set the tristating for the IO port.
  //TRIS is not a physical register, so it must be set using TRIS.
  #asm
    //Set the GP pins.
    //GP0 is X;   input
    //GP1 is Y;    input
    //GP2 is Z;   output
    //GP3 is A;   input. (The pin is input only)
    movlw 0b00000000
    movwf GPIO
    movlw 0b11111011
    tris  GPIO
  #endasm
Second, if you're using quickwriter, you'll have to fight it tooth and nail to keep the MRCLR fuse disabled. If you've got input on that pin, it might just reset the pic instead of doing what you expect.
Reviewing your code, it looks like you have a few extra #use rs232 and include files in there that you should get rid of. Also, with the #use delay set at 20MHz, the 4MHz clock isn't going to sync right.
In the 90's, I promised myself I'd never use a so-called "smiley icon". I hate what I've become. ;)
john bougs
PostPosted: Mon Feb 14, 2005 3:33 pm     Reply with quote
Thanks the comparator was the problem. Things are happy now.
