18f252 array problem
TEK66TIM
PostPosted: Thu Feb 10, 2005 5:19 pm     Reply with quote
Hi, having a problem with arrays on the 18f252 part with compiler version
PCW 3.115 IDE version 3.21. The array reads back fine untill element 244
after 244 it reads back junk. I have tried the #locate directive and it does not work at all. I'm new to posting code to the forum so I hope this works,any help would be great.
Thanks in advance
Tim
#include <18f252.h>
#include <stdlib.h>
#fuses NOLVP, NOWDT, EC_IO
#use delay (clock=40000000)
#use rs232 (baud=9600, xmit=PIN_A6, rcv=PIN_C7)
#define DEBUG PIN_A6
#define CHSEL PIN_C6
#define N_STATUS PIN_A0
#define CONF_DONE PIN_A1
#define INIT_DONE PIN_A2
#define DATA_0 PIN_A3
#define N_CONFIG PIN_A4
#define DCLK PIN_A5
// functions
void blink_led ();
void read_ser_port ();
// variables
int8 data_array_1 [300];
int1 eof_flag = 0;
// constants
// mem locations
//#locate data_array_1 = 0x100     // tried this un-commented, array reads back junk. commented out it reads back fine until element 244
void main (void)
   int8 data;
   output_float (N_STATUS);      // tri-state pins for PLD programming interface
   output_float (CONF_DONE);
   output_float (INIT_DONE);
   output_float (DATA_0);
   output_float (N_CONFIG);
   output_float (DCLK);
   output_high (CHSEL);    // de-select serial eeprom
   delay_ms (1000);     // let PCB settle after powerup
   blink_led ();     // blink LEDS to let me know it's alive
   blink_led ();
   blink_led ();
   blink_led ();
   blink_led ();
   do
      data = getc ();
      if (data == 0x01)
         read_ser_port ();
   while (1);     // loop to get serial port handshake
void read_ser_port ()      // this should read 270 bytes from serial port then print them back to the computer
   int16 count;
   do
      putc (0xAA);
      for (count = 0; count < 270; count ++)
         data_array_1 [count] = getc ();
         printf ("count = %Lu data = %x \n\r", count, data_array_1 [count]);
   while (1);
void blink_led ()    // blinks LED
   output_low (DEBUG);
   delay_ms (200);
   output_high (DEBUG);
   delay_ms (200);
PostPosted: Fri Feb 11, 2005 1:29 am     Reply with quote
version PCW 3.115
That's a fairly old version. It could easily have a bug in that area.
If you can't upgrade, then maybe you could break it up into two
smaller arrays. This might fix it.
TEK66TIM
PostPosted: Fri Feb 11, 2005 7:43 am     Reply with quote
Funny thing, I tried this ( two 135 byte arrays ) each array ran fine for the first 110 bytes, then produced junk. Then I tried two 100 byte arrays and one 70 byte array. the first array was fine the second and third produced junk again.
