cfernandez
SERIAL BUG or PIC Problem??????????????????? |
Posted: Wed Feb 09, 2005 10:56 am |
I have a problem with my project in 18F4620 20Mhz, I need to obtain data from UART (C6,C7) to 115k and the fgetc NOT WORK. I try with FORCE_SW and this clausule work in 57600 but not in 115k. I remove the directive #ZERO_RAM and fgetc work in 115k without clausule FORCE_SW.
The other problem with solution is that I can not comunicate with my serial device (C1,C2) to 115k, the solution is put the clausule SAMPLE_EARLY in the #USE definition. This is a bug from compiler or a bug from Microchip 4620?
Somebody know which is the problem with ZERO_RAM clausule.
I hope that this information help to you in found the solution.
Thank you very much!
Best Regards, |
cfernandez
CONTINUE....
I send a simple program for test the fgetc
This LST not work fgetc (BAD)
MPASM
CCS PCH C Compiler, Version 3.218, 25972 09-Feb-05 03:41
Filename: Test.LST
ROM used: 132 bytes (0%)
Largest free fragment is 65404
RAM used: 6 (0%) at main() level
6 (0%) worst case
Stack: 0 locations
0000 EF02 F000 00001 GOTO 0004
0000 00002 .................... #include <18F4620.h>
0000 00003 .................... //////// Standard Header file for the PIC18F4620 device ////////////////
0000 00004 .................... #device PIC18F4620
0000 00413 .................... #list
0000 00414 ....................
0000 00415 .................... #device *=16
0000 00416 .................... #device adc=8
0000 00417 .................... #case
0000 00418 .................... #use delay(clock=20000000)
0000 00419 .................... #fuses HS,NOWDT,NOLVP,PROTECT
0000 00420 .................... #opt 11
0000 00421 .................... #zero_ram
0000 00422 ....................
0000 00423 .................... #use rs232( BAUD = 115200, PARITY = N, XMIT = PIN_C6, RCV = PIN_C7, BITS = 8, STREAM = SERIAL_2 ) //, FORCE_SW, ERRORS )
0000 00424 ....................
0000 00425 .................... void main()
0000 00426 .................... {
0004 6AF8 00427 CLRF FF8
0006 9ED0 00428 BCF FD0.7
0008 0EFE 00429 MOVLW FE
000A 6E00 00430 MOVWF 00
000C 0E10 00431 MOVLW 10
000E 6E01 00432 MOVWF 01
0010 6AEA 00433 CLRF FEA
0012 0E02 00434 MOVLW 02
0014 6EE9 00435 MOVWF FE9
0016 6AEF 00436 CLRF FEF
0018 2AE9 00437 INCF FE9,F
001A B4D8 00438 BTFSC FD8.2
001C 2AEA 00439 INCF FEA,F
001E 2E00 00440 DECFSZ 00,F
0020 D7FA 00441 BRA 0016
0022 2E01 00442 DECFSZ 01,F
0024 D7F8 00443 BRA 0016
0026 6AEA 00444 CLRF FEA
0028 6AE9 00445 CLRF FE9
002A 50C1 00446 MOVF FC1,W
002C 0BC0 00447 ANDLW C0
002E 090F 00448 IORLW 0F
0030 6EC1 00449 MOVWF FC1
0032 0E07 00450 MOVLW 07
0034 6EB4 00451 MOVWF FB4
0036 50B4 00452 MOVF FB4,W
0038 9CA1 00453 BCF FA1.6
003A 86B8 00454 BSF FB8.3
003C 0E2A 00455 MOVLW 2A
003E 6EAF 00456 MOVWF FAF
0040 0E26 00457 MOVLW 26
0042 6EAC 00458 MOVWF FAC
0044 0E90 00459 MOVLW 90
0046 6EAB 00460 MOVWF FAB
0000 00461 .................... //
0000 00462 .................... // Defino variables locales
0000 00463 .................... //
0000 00464 .................... char cCh;
0000 00465 ....................
0000 00466 .................... fprintf( SERIAL_2, ">" );
0048 0E3E 00467 MOVLW 3E
004A A89E 00468 BTFSS F9E.4
004C D7FE 00469 BRA 004A
004E 6EAD 00470 MOVWF FAD
0000 00471 .................... cCh = fgetc( SERIAL_2 );
0050 AA9E 00472 BTFSS F9E.5
0052 D7FE 00473 BRA 0050
0054 CFAE F006 00474 MOVFF FAE,06
0000 00475 .................... fprintf( SERIAL_2, "%c\n\r", cCh );
0058 5006 00476 MOVF 06,W
005A A89E 00477 BTFSS F9E.4
005C D7FE 00478 BRA 005A
005E 6EAD 00479 MOVWF FAD
0060 0E0A 00480 MOVLW 0A
0062 A89E 00481 BTFSS F9E.4
0064 D7FE 00482 BRA 0062
0066 6EAD 00483 MOVWF FAD
0068 0E0D 00484 MOVLW 0D
006A A89E 00485 BTFSS F9E.4
006C D7FE 00486 BRA 006A
006E 6EAD 00487 MOVWF FAD
0000 00488 ....................
0000 00489 .................... fprintf( SERIAL_2, "\n\r" );
0070 0E0A 00490 MOVLW 0A
0072 A89E 00491 BTFSS F9E.4
0074 D7FE 00492 BRA 0072
0076 6EAD 00493 MOVWF FAD
0078 0E0D 00494 MOVLW 0D
007A A89E 00495 BTFSS F9E.4
007C D7FE 00496 BRA 007A
007E 6EAD 00497 MOVWF FAD
0000 00498 .................... while( TRUE );
0080 D7FF 00499 BRA 0080
0000 00500 .................... }
0000 00501 ....................
0082 0003 0502 SLEEP
Configuration Fuses:
Word 1: C200 HS IESO FCMEN
Word 2: 1E1F BROWNOUT NOWDT BORV21 NOPUT WDT32768
Word 3: 8700 CCP2C1 PBADEN LPT1OSC MCLR
Word 4: 0081 STVREN NODEBUG NOLVP NOXINST
Word 5: C000 PROTECT NOCPD NOCPB
Word 6: E00F NOWRT NOWRTD NOWRTC NOWRTB
Word 7: 400F NOEBTR NOEBTRB
SYMBOL TABLE
LABEL VALUE
_RETURN_ 00000001
main.cCh 00000006
PSP_DATA 00000F83
C1OUT 00000FB4
C2OUT 00000FB4
CCP_2 00000FBB
CCP_2_LOW 00000FBB
CCP_2_HIGH 00000FBC
CCP_1 00000FBE
CCP_1_LOW 00000FBE
CCP_1_HIGH 00000FBF
main 00000004
MEMORY USAGE |
This LST work fgetc (GOOD)
MPASM
CCS PCH C Compiler, Version 3.218, 25972 09-Feb-05 03:42
Filename: C:\Documents and Settings\cfernandez\Escritorio\Metro AM\ftes\AMDK-Test\iMFR\iMFR-BAD\Test.LST
ROM used: 102 bytes (0%)
Largest free fragment is 65434
6 (0%) worst case
Stack: 0 locations
0000 00421 .................... //#zero_ram
0008 6AEA 00429 CLRF FEA
000A 6AE9 00430 CLRF FE9
000C 50C1 00431 MOVF FC1,W
000E 0BC0 00432 ANDLW C0
0010 090F 00433 IORLW 0F
0012 6EC1 00434 MOVWF FC1
0014 0E07 00435 MOVLW 07
0016 6EB4 00436 MOVWF FB4
0018 50B4 00437 MOVF FB4,W
001A 9CA1 00438 BCF FA1.6
001C 86B8 00439 BSF FB8.3
001E 0E2A 00440 MOVLW 2A
0020 6EAF 00441 MOVWF FAF
0022 0E26 00442 MOVLW 26
0024 6EAC 00443 MOVWF FAC
0026 0E90 00444 MOVLW 90
0028 6EAB 00445 MOVWF FAB
0000 00446 .................... //
0000 00447 .................... // Defino variables locales
0000 00448 .................... //
0000 00449 .................... char cCh;
0000 00450 ....................
0000 00451 .................... fprintf( SERIAL_2, ">" );
002A 0E3E 00452 MOVLW 3E
002C A89E 00453 BTFSS F9E.4
002E D7FE 00454 BRA 002C
0030 6EAD 00455 MOVWF FAD
0000 00456 .................... cCh = fgetc( SERIAL_2 );
0032 AA9E 00457 BTFSS F9E.5
0034 D7FE 00458 BRA 0032
0036 CFAE F006 00459 MOVFF FAE,06
0000 00460 .................... fprintf( SERIAL_2, "%c\n\r", cCh );
003A 5006 00461 MOVF 06,W
003C A89E 00462 BTFSS F9E.4
003E D7FE 00463 BRA 003C
0040 6EAD 00464 MOVWF FAD
0042 0E0A 00465 MOVLW 0A
0044 A89E 00466 BTFSS F9E.4
0046 D7FE 00467 BRA 0044
0048 6EAD 00468 MOVWF FAD
004A 0E0D 00469 MOVLW 0D
004C A89E 00470 BTFSS F9E.4
004E D7FE 00471 BRA 004C
0050 6EAD 00472 MOVWF FAD
0000 00473 ....................
0000 00474 .................... fprintf( SERIAL_2, "\n\r" );
0052 0E0A 00475 MOVLW 0A
0054 A89E 00476 BTFSS F9E.4
0056 D7FE 00477 BRA 0054
0058 6EAD 00478 MOVWF FAD
005A 0E0D 00479 MOVLW 0D
005C A89E 00480 BTFSS F9E.4
005E D7FE 00481 BRA 005C
0060 6EAD 00482 MOVWF FAD
0000 00483 .................... while( TRUE );
0062 D7FF 00484 BRA 0062
0000 00485 .................... }
0000 00486 ....................
0064 0003 0487 SLEEP
SYMBOL TABLE
LABEL VALUE
_RETURN_ 00000001
main.cCh 00000006
PSP_DATA 00000F83
C1OUT 00000FB4
C2OUT 00000FB4
CCP_2 00000FBB
CCP_2_LOW 00000FBB
CCP_2_HIGH 00000FBC
CCP_1 00000FBE
CCP_1_LOW 00000FBE
CCP_1_HIGH 00000FBF
main 00000004
MEMORY USAGE
Posted: Wed Feb 09, 2005 6:06 pm |
Some small background info on RS232:
The sample clock is only allowed to have an frequency error of about 3%. A data byte consists of 10 bits (8 data bits, a start bit and a stop bit), 10 times 3% error = 30% total error. With bad quality lines the error margin will drop to 2% or below. Maxim has a good application note on this, too bad I can't find the link now.
This 3% error margin is combined for both the sender and transmitter!
In your 2nd example code with the hardware UART the baudrate is set to 20MHz/4( 0x2A + 1) = 116.279 baud, a positive error of almost 1%. If your transmitter has an error of -2% or more you will receive garbage.
Many PCs are known to have large frequency offsets....
Do you have a scope? If yes, you can check the timing of the other device.
Or just quick, try the effect of reducing the baudrate in your 2nd example to 113k5.
A good thing with the hardware UART is to add the 'ERRORS' directive which will clear the error bits in the UART for you (otherwise the UART will stop receiving).
Edit: Removed an invalid remark about software UARTs.
cfernandez
Posted: Wed Feb 09, 2005 6:12 pm |
Thank you very much!! for explain me this. But the problem not is the baud rate, is the ZERO_RAM.
I send this to CCS support and they tell me:
CCS Support wrote:
> This message is a reply to CCS e-mail id: 5B2624
> There is a problem with #ZERO_RAM on this part. Do not use it until the next release.
The next release is the Friday.
What you do think?
Best Regards, |
Posted: Wed Feb 09, 2005 6:44 pm |
Comparing your two examples I don't see how the #zero_ram is affecting the hardware UART. Both generated assembly listings are equal, except for the RAM clearing part. The RAM clearing part only writes to RAM, not to any of the UART related file registers as far as I can see.
I still think you can fix your problem by configuring the next lower baudrate of 113k5. Especially the fact that the software UART started working when you enabled early sampling is a good hint in this direction. |
cfernandez
Posted: Wed Feb 09, 2005 10:20 pm |
I have too many problems with my 18F4620, I dont know if all problems are bugs or the microchip part have some problem. The point is that the problem exist!, if a case for the RIPLEY's
Other strange problem is that my board to 20Mhz can comunicate by the UART to 115kb excellent, but I change the crystal to 25Mhz and to 115Kb I see garbage!!. Now I am crazy!!, I want to found some people that develop on 18F4620 and CCS and ask if have some problem.
Sorry by my english.
Thank you very much!. |
Posted: Thu Feb 10, 2005 4:06 am |
Quote: | Other strange problem is that my board to 20Mhz can comunicate by the UART to 115kb excellent, but I change the crystal to 25Mhz and to 115Kb I see garbage!!. Now I am crazy!!, I want to found some people that develop on 18F4620 and CCS and ask if have some problem. |
Your problem is that you can not use this PICs directly with a 25MHz crystal and fuses in HS-mode. The maximum speed of an external crystal can be 20MHz, see table 26-6 of the 18F4620 manual. If you want to run at higher frequencies you use either the 4x PLL multiplier or an external clock driver. For example, 40MHz can be achieved with a 10MHz crystal and setting the fuses to HS+PLL.
Funny how people come up with the same problems in a short time span, in the last two days you are the 3rd person having troubles with running at high clock speeds above 20MHz. |
cfernandez
Posted: Thu Feb 10, 2005 7:56 am |
Dear ckielstra,
Thank you very much!, for your information.
I have a question, Why in the table 2-2 Page 24 say 25Mhz????. and where you see that other people have the same problem?
Best Regards, |
rwyoung
Posted: Thu Feb 10, 2005 8:54 am |
cfernandez wrote: | Dear ckielstra,
Best Regards, |
I don't feel like grabbing a copy of the data sheet but does it say 25MHz "CRYSTAL" or 25MHz "OSCILLATOR". Two very different things. _________________ Rob Young
Posted: Thu Feb 10, 2005 9:07 am |
Quote: | I have a question, Why in the table 2-2 Page 24 say 25Mhz???? | It must be a bug in the manual. Some other processors like the 18F458 are specified up to 25MHz for crystal oscillators. You might be lucky to find some samples to work at 25MHz but no garuantee. If you want to run faster than 20MHz. Your processor will run up to 40Mhz when using either an external clock driver or a slower crystal in combination with the internal 4x frequency multiplier. |
rwyoung
Posted: Thu Feb 10, 2005 11:11 am |
ckielstra wrote: | Quote: | I have a question, Why in the table 2-2 Page 24 say 25Mhz???? | It must be a bug in the manual. Some other processors like the 18F458 are specified up to 25MHz for crystal oscillators. You might be lucky to find some samples to work at 25MHz but no garuantee. If you want to run faster than 20MHz. Your processor will run up to 40Mhz when using either an external clock driver or a slower crystal in combination with the internal 4x frequency multiplier. |
Definately a typo in table 2-2. Didn't see any correction made in the errata either. _________________ Rob Young
cfernandez
Posted: Thu Feb 10, 2005 11:55 am |
I make a ticket in Microchip support and this is your answer:
** PLEASE DO NOT RESPOND TO THIS AUTOMATED MESSAGE VIA E-MAIL **
** TO RESPOND SUBMIT ADDITIONAL COMMENTS TO THIS TICKET ON SUPPORT.MICROCHIP.COM **
Below is a response from Microchip Engineering Support Team for your submitted ticket #: 1-13744
A description of the problem and our proposed resolution is contained below.
Area: PICmicro Products
Product Group: PIC18FXX20
Product: PIC18F4620
Problem Description:
I have a some question:
Question 1)
We buy 30 parts 18F4620 in DigiKey, and the idea are use this with 25Mhz and 115Kb, but we have problem with the UART for this speed, we change the crystal to 20Mhz and the UART in 115Kb work OK.
I see that in the table 2-2 of 18F4620 (39626b.pdf) say 25Mhz, but now I see that in the table 26-6 say that the max. speed in HS is 20Mhz.
Can you explain me this difference.
Question 2)
Exist some bug in the 18F4620 parts??
Question 3)
How to idenfy if my parts are OK or are lots with bugs?
Question 4)
I try with 10Mhz PLL and I have garbage in the comunication, This feature work fine?
I wait your answer for make a new order to DigiKey for 100 parts more.
Bert Regards,
Problem Resolution:
For a 25Mhz oscillator the error in baud rate will be just over 13%, which is greater than the tlerances in the rs-232 spec.
Dropping the oscilator frequency to 20 mhz will improve the baud rate error to under 9.6% which may be close enough.
There is an error in the datasheet where HS oscillator mode is rated to 25 Mhz. There is curently documentation rectifying this in the process of being published.
There are several errata items in teh PIC18F4620 these are covered in the errata document.
http://ww1.microchip.com/downloads/en/DeviceDoc/80224a.pdf
The errata applies to the currently available devices.
You should be able to clock the device at 40 mhz with an external 10 mhz cyrstal and the x4 PLL. You may have to check your baud rate and configuration of the USART.
If the resolution provided does not solve your problem, you may respond back to the support team through the web interface at support.microchip.com. Telephone support is also available Monday-Thursday between the hours of 7:30am and 4:00pm MST and on Friday between 10:00am and 4:00pm. You may contact the Support department by calling (480) 792-7627. You will be prompted to enter the Ticket ID shown in the subject line of this message for verification. Enter the Ticket ID which is 1-13744 substituting the '-' with the '*' key. Press # on your telephone when finished.
Please do not respond to this message via e-mail.
Microchip Engineering Support |
cfernandez
Posted: Thu Feb 10, 2005 11:58 am |
Where found the exactly documentation for know why 115kb in 25Mhz have more errors that 115kb in 20Mhz.
I remenber see this doc in microchip, but now I not found. Somebody know where is this?
Thanks, |
Chas Guest
Posted: Thu Feb 10, 2005 12:40 pm |
I find it most curious that when I go to Microchip's website and search for the PIC18F4620 that there are no errata sheets in the search results. There are for most other processors. If you check the document in the above post by cfernandez, it is 10 pages long!!! I wonder what other dirty little secrets, oops I mean errata sheets, are lurking in the weeds??? |
treitmey
Posted: Thu Feb 10, 2005 12:43 pm |
16F877A,.. oops that doesn't go to 25Mhz
