unions
alexz
unions
PostPosted: Wed Feb 09, 2005 5:51 am     Reply with quote
I have got the following structure:
struct HostCBW
BYTE Signature[4];
BYTE Tag[4];
BYTE DataTransferLen[4];
BYTE CBWFlags; BYTE CBWLUN;
BYTE CBLength;
BYTE CBWCB[16];
And the following union:
union CommandBlockWrapper
struct HostCBW CBWField;
BYTE CBWBuffer[31];
}CBW;
How can I modify this union, to have the CBW.CBWField.CBWCB[0] to be at the same address as an additional byte variable?
In other words that I will be able to call this particular byte using a different name.
Alex
Charlie U
PostPosted: Wed Feb 09, 2005 7:38 am     Reply with quote
The structure and the array in the union are just overlapped. You can access the first byte of the union by using either
CBW.CBWBuffer[0]
or
CBW.CBWField.Signature[0].
The other bytes are just accessed similarly in the order that you have declared them.
alexz
PostPosted: Wed Feb 09, 2005 7:42 am     Reply with quote
CBW.CBWBuffer[0]
or
Yeah, I know that.
What I mean is, you can use those two different names because thay are at the same address.
I want #define newname CBW.CBWField.Signature[0]
but the same way as in unions. to have another variable at the same address
Alex
