STRANGE PROBLEM IN 18F4620
cfernandez
PostPosted: Tue Feb 08, 2005 8:16 am     Reply with quote
I have a very strange problem, in the attach LST if I change the size of variable sBuffer ( in the main section) with the define MF_BUFFER_SIZE to < 239 bytes I not received nothing!!!!! by my SERIAL_MF stream. If I define the size to 255 work.
With the 18F8720 work ok in two sizes.
Is a bug? or a programming problem?, or the C1 & C2 are the problem?
Somebody know why happend this?
Thank you very much!!
cfernandez
PostPosted: Tue Feb 08, 2005 8:17 am     Reply with quote
This is the LST CODE.
MPASM
CCS PCH C Compiler, Version 3.218, 25972               08-Feb-05 11:14
               Filename: iMFRTest.LST
               ROM used: 1002 bytes (2%)
                         Largest free fragment is 64534
               RAM used: 43 (1%) at main() level
                         57 (1%) worst case
               Stack:    4 locations
0000 EF85 F001      00001 GOTO   030A
0000                00002 ....................  #include <18F4620.h>
0000                00003 ....................  //////// Standard Header file for the PIC18F4620 device ////////////////
0000                00004 .................... #device PIC18F4620
0000                00558 .................... #list
0000                00559 ....................
0000                00560 .................... #device *=16
0000                00561 .................... #device adc=8
0000                00562 .................... #case
0000                00563 .................... #use delay(clock=25000000)
0000                00564 .................... #fuses  HS,NOWDT,NOLVP,PROTECT
0000                00565 .................... #opt 11
0000                00566 .................... #ignore_warnings 203,204,205,206
0000                00567 .................... #zero_ram
0000                00568 .................... #use rs232( BAUD =  115200, PARITY = N, XMIT = PIN_C6, RCV = PIN_C7, BITS = 8, STREAM = SERIAL_2 ) //, ERRORS, DISABLE_INTS )
0000                00569 ....................
0000                00570 .................... #use rs232( BAUD= 115200, PARITY = N, XMIT = PIN_C2, RCV = PIN_C1, BITS = 8, STREAM = SERIAL_MF, SAMPLE_EARLY, FORCE_SW, ERRORS  )
01C8 9494           00571 BCF    F94.2
01CA 948B           00572 BCF    F8B.2
01CC 0E08           00573 MOVLW  08
01CE 6E01           00574 MOVWF  01
01D0 0000           00575 NOP
01D2 0000           00576 NOP
01D4 0000           00577 NOP
01D6 8E01           00578 BSF    01.7
01D8 D013           00579 BRA    0200
01DA 9E01           00580 BCF    01.7
01DC C031 F002      00581 MOVFF  31,02
01E0 3202           00582 RRCF   02,F
01E2 B0D8           00583 BTFSC  FD8.0
01E4 848B           00584 BSF    F8B.2
01E6 A0D8           00585 BTFSS  FD8.0
01E8 948B           00586 BCF    F8B.2
01EA 8C01           00587 BSF    01.6
01EC D009           00588 BRA    0200
01EE 9C01           00589 BCF    01.6
01F0 2E01           00590 DECFSZ 01,F
01F2 D7F6           00591 BRA    01E0
01F4 C002 F031      00592 MOVFF  02,31
01F8 0000           00593 NOP
01FA 0000           00594 NOP
01FC 0000           00595 NOP
01FE 848B           00596 BSF    F8B.2
0200 0E0B           00597 MOVLW  0B
0202 6EE9           00598 MOVWF  FE9
0204 2EE9           00599 DECFSZ FE9,F
0206 D7FE           00600 BRA    0204
0208 BE01           00601 BTFSC  01.7
020A D7E7           00602 BRA    01DA
020C BC01           00603 BTFSC  01.6
020E D7EF           00604 BRA    01EE
0210 EF23 F001      00605 GOTO   0246 (RETURN)
0262 0E08           00606 MOVLW  08
0264 6E00           00607 MOVWF  00
0266 8294           00608 BSF    F94.1
0268 B282           00609 BTFSC  F82.1
026A D7FE           00610 BRA    0268
026C 6A34           00611 CLRF   34
026E 9E00           00612 BCF    00.7
0270 D00E           00613 BRA    028E
0272 C034 F002      00614 MOVFF  34,02
0276 90D8           00615 BCF    FD8.0
0278 B282           00616 BTFSC  F82.1
027A 80D8           00617 BSF    FD8.0
027C 3202           00618 RRCF   02,F
027E 8C00           00619 BSF    00.6
0280 D006           00620 BRA    028E
0282 9C00           00621 BCF    00.6
0284 2E00           00622 DECFSZ 00,F
0286 D7F7           00623 BRA    0276
0288 C002 F001      00624 MOVFF  02,01
028C D00D           00625 BRA    02A8
028E 0E0B           00626 MOVLW  0B
0290 BE00           00627 BTFSC  00.7
0292 0E03           00628 MOVLW  03
0294 6E01           00629 MOVWF  01
0296 2E01           00630 DECFSZ 01,F
0298 D7FE           00631 BRA    0296
029A 0000           00632 NOP
029C 0000           00633 NOP
029E BE00           00634 BTFSC  00.7
02A0 D7E6           00635 BRA    026E
02A2 BC00           00636 BTFSC  00.6
02A4 D7EE           00637 BRA    0282
02A6 D7E7           00638 BRA    0276
02A8 EF6E F001      00639 GOTO   02DC (RETURN)
0000                00640 ....................
0000                00641 ....................
0000                00642 ....................
0000                00643 .................... #define MF_SERIAL_PORT                  SERIAL_MF
0000                00644 .................... #define MF_DEBUG_PORT                  SERIAL_2
0000                00645 ....................
0000                00646 ....................
0000                00647 .................... #define MF_RESPONSE_TIMEOUT               25000
0000                00648 .................... #define MF_TRANSMIT_TIMEOUT               50
0000                00649 ....................
0000                00650 .................... #define MF_BUFFER_SIZE                  32
0000                00651 ....................
0000                00652 ....................
0000                00653 ....................
0000                00654 .................... void MF_Debug( int1 siTXRX, char *sData, int iDataLen )
0000                00655 .................... {
0000                00656 ....................    int    iPtr;
0000                00657 ....................
0000                00658 ....................    if ( siTXRX )
0130 5230           00659 MOVF   30,F
0132 E00B           00660 BZ    014A
0000                00661 ....................       fprintf( MF_DEBUG_PORT, "%s", "TX" );
0134 6A35           00662 CLRF   35
0136 5035           00663 MOVF   35,W
0138 DF65           00664 RCALL  0004
013A 0900           00665 IORLW  00
013C E005           00666 BZ    0148
013E 2A35           00667 INCF   35,F
0140 A89E           00668 BTFSS  F9E.4
0142 D7FE           00669 BRA    0140
0144 6EAD           00670 MOVWF  FAD
0146 D7F7           00671 BRA    0136
0000                00672 ....................    else
0148 D00A           00673 BRA    015E
0000                00674 ....................       fprintf( MF_DEBUG_PORT, "%s", "RX" );
014A 6A35           00675 CLRF   35
014C 5035           00676 MOVF   35,W
014E DF64           00677 RCALL  0018
0150 0900           00678 IORLW  00
0152 E005           00679 BZ    015E
0154 2A35           00680 INCF   35,F
0156 A89E           00681 BTFSS  F9E.4
0158 D7FE           00682 BRA    0156
015A 6EAD           00683 MOVWF  FAD
015C D7F7           00684 BRA    014C
0000                00685 ....................
0000                00686 ....................    fprintf( MF_DEBUG_PORT, "(%03U) [", iDataLen );
015E 0E28           00687 MOVLW  28
0160 A89E           00688 BTFSS  F9E.4
0162 D7FE           00689 BRA    0160
0164 6EAD           00690 MOVWF  FAD
0166 C033 F035      00691 MOVFF  33,35
016A 6A36           00692 CLRF   36
016C D773           00693 BRA    0054
016E 0E29           00694 MOVLW  29
0170 A89E           00695 BTFSS  F9E.4
0172 D7FE           00696 BRA    0170
0174 6EAD           00697 MOVWF  FAD
0176 0E20           00698 MOVLW  20
0178 A89E           00699 BTFSS  F9E.4
017A D7FE           00700 BRA    0178
017C 6EAD           00701 MOVWF  FAD
017E 0E5B           00702 MOVLW  5B
0180 A89E           00703 BTFSS  F9E.4
0182 D7FE           00704 BRA    0180
0184 6EAD           00705 MOVWF  FAD
0000                00706 ....................
0000                00707 ....................    for ( iPtr = 0 ; iPtr < iDataLen ; iPtr++ )
0186 6A34           00708 CLRF   34
0188 5033           00709 MOVF   33,W
018A 5C34           00710 SUBWF  34,W
018C E210           00711 BC    01AE
0000                00712 ....................       fprintf( MF_DEBUG_PORT, "%02X", sData[ iPtr ] );
018E 6A03           00713 CLRF   03
0190 5034           00714 MOVF   34,W
0192 2431           00715 ADDWF  31,W
0194 6EE9           00716 MOVWF  FE9
0196 5032           00717 MOVF   32,W
0198 2003           00718 ADDWFC 03,W
019A 6EEA           00719 MOVWF  FEA
019C CFEF F035      00720 MOVFF  FEF,35
01A0 C035 F036      00721 MOVFF  35,36
01A4 0E37           00722 MOVLW  37
01A6 6E37           00723 MOVWF  37
01A8 D7A1           00724 BRA    00EC
01AA 2A34           00725 INCF   34,F
01AC D7ED           00726 BRA    0188
0000                00727 ....................
0000                00728 ....................    fprintf( MF_DEBUG_PORT, "]\n\r" );
01AE 0E5D           00729 MOVLW  5D
01B0 A89E           00730 BTFSS  F9E.4
01B2 D7FE           00731 BRA    01B0
01B4 6EAD           00732 MOVWF  FAD
01B6 0E0A           00733 MOVLW  0A
01B8 A89E           00734 BTFSS  F9E.4
01BA D7FE           00735 BRA    01B8
01BC 6EAD           00736 MOVWF  FAD
01BE 0E0D           00737 MOVLW  0D
01C0 A89E           00738 BTFSS  F9E.4
01C2 D7FE           00739 BRA    01C0
01C4 6EAD           00740 MOVWF  FAD
0000                00741 .................... }
01C6 0C00           00742 RETLW  00
0000                00743 ....................
0000                00744 ....................
0000                00745 ....................
0000                00746 .................... void MF_Kbhit( int16 lTimeOut )
0000                00747 .................... {
0000                00748 ....................    while ( !kbhit( MF_SERIAL_PORT ) && --lTimeOut );
024E A282           00749 BTFSS  F82.1
0250 D007           00750 BRA    0260
0252 502F           00751 MOVF   2F,W
0254 B4D8           00752 BTFSC  FD8.2
0256 0630           00753 DECF   30,F
0258 062F           00754 DECF   2F,F
025A 502F           00755 MOVF   2F,W
025C 1030           00756 IORWF  30,W
025E E1F7           00757 BNZ   024E
0000                00758 .................... }
0260 0C00           00759 RETLW  00
0000                00760 ....................
0000                00761 ....................
0000                00762 ....................
0000                00763 .................... void MF_SendFrame( char *sData, int iDataLen )
0000                00764 .................... {
0000                00765 ....................    int      iPtr;
0000                00766 ....................
0000                00767 ....................    MF_Debug( TRUE, sData, iDataLen );
0214 0E01           00768 MOVLW  01
0216 6E30           00769 MOVWF  30
0218 C02D F032      00770 MOVFF  2D,32
021C C02C F031      00771 MOVFF  2C,31
0220 C02E F033      00772 MOVFF  2E,33
0224 DF85           00773 RCALL  0130
0000                00774 ....................
0000                00775 ....................    for ( iPtr = 0 ; iPtr < iDataLen ; iPtr++ )
0226 6A2F           00776 CLRF   2F
0228 502E           00777 MOVF   2E,W
022A 5C2F           00778 SUBWF  2F,W
022C E20E           00779 BC    024A
0000                00780 ....................       fputc( sData[ iPtr ], MF_SERIAL_PORT );
022E 6A03           00781 CLRF   03
0230 502F           00782 MOVF   2F,W
0232 242C           00783 ADDWF  2C,W
0234 6EE9           00784 MOVWF  FE9
0236 502D           00785 MOVF   2D,W
0238 2003           00786 ADDWFC 03,W
023A 6EEA           00787 MOVWF  FEA
023C CFEF F030      00788 MOVFF  FEF,30
0240 C030 F031      00789 MOVFF  30,31
0244 D7C1           00790 BRA    01C8
0246 2A2F           00791 INCF   2F,F
0248 D7EF           00792 BRA    0228
0000                00793 .................... }
024A EFE5 F001      00794 GOTO   03CA (RETURN)
0000                00795 ....................
0000                00796 ....................
0000                00797 ....................
0000                00798 .................... int MF_RecvFrame( char *sData )
0000                00799 .................... {
0000                00800 ....................    int      iLen = 0;
02AC 6A2E           00801 CLRF   2E
0000                00802 ....................
0000                00803 ....................    MF_Kbhit( MF_RESPONSE_TIMEOUT );
02AE 0E61           00804 MOVLW  61
02B0 6E30           00805 MOVWF  30
02B2 0EA8           00806 MOVLW  A8
02B4 6E2F           00807 MOVWF  2F
02B6 DFCB           00808 RCALL  024E
0000                00809 ....................
0000                00810 ....................    while ( kbhit( MF_SERIAL_PORT ) && iLen < MF_BUFFER_SIZE )
0000                00811 ....................    {
02B8 B282           00812 BTFSC  F82.1
02BA D01B           00813 BRA    02F2
02BC 502E           00814 MOVF   2E,W
02BE 081F           00815 SUBLW  1F
02C0 E318           00816 BNC   02F2
0000                00817 ....................       sData[ iLen++ ] = fgetc( MF_SERIAL_PORT );
02C2 502E           00818 MOVF   2E,W
02C4 2A2E           00819 INCF   2E,F
02C6 6A03           00820 CLRF   03
02C8 242C           00821 ADDWF  2C,W
02CA 6EE9           00822 MOVWF  FE9
02CC 502D           00823 MOVF   2D,W
02CE 2003           00824 ADDWFC 03,W
02D0 6EEA           00825 MOVWF  FEA
02D2 CFEA F033      00826 MOVFF  FEA,33
02D6 CFE9 F032      00827 MOVFF  FE9,32
02DA D7C3           00828 BRA    0262
02DC C033 FFEA      00829 MOVFF  33,FEA
02E0 C032 FFE9      00830 MOVFF  32,FE9
02E4 C001 FFEF      00831 MOVFF  01,FEF
0000                00832 ....................       MF_Kbhit( MF_TRANSMIT_TIMEOUT );
02E8 6A30           00833 CLRF   30
02EA 0E32           00834 MOVLW  32
02EC 6E2F           00835 MOVWF  2F
02EE DFAF           00836 RCALL  024E
0000                00837 ....................    }
02F0 D7E3           00838 BRA    02B8
0000                00839 ....................
0000                00840 ....................    MF_Debug( FALSE, sData, iLen );
02F2 6A30           00841 CLRF   30
02F4 C02D F032      00842 MOVFF  2D,32
02F8 C02C F031      00843 MOVFF  2C,31
02FC C02E F033      00844 MOVFF  2E,33
0300 DF17           00845 RCALL  0130
0000                00846 ....................
0000                00847 ....................    return iLen;
0302 C02E F001      00848 MOVFF  2E,01
0000                00849 .................... }
0306 EFE9 F001      00850 GOTO   03D2 (RETURN)
0000                00851 ....................
0000                00852 ....................
0000                00853 ....................
0000                00854 .................... void main()
0000                00855 .................... {
030A 6AF8           00856 CLRF   FF8
030C 9ED0           00857 BCF    FD0.7
030E 0EFE           00858 MOVLW  FE
0310 6E00           00859 MOVWF  00
0312 0E10           00860 MOVLW  10
0314 6E01           00861 MOVWF  01
0316 6AEA           00862 CLRF   FEA
0318 0E02           00863 MOVLW  02
031A 6EE9           00864 MOVWF  FE9
031C 6AEF           00865 CLRF   FEF
031E 2AE9           00866 INCF   FE9,F
0320 B4D8           00867 BTFSC  FD8.2
0322 2AEA           00868 INCF   FEA,F
0324 2E00           00869 DECFSZ 00,F
0326 D7FA           00870 BRA    031C
0328 2E01           00871 DECFSZ 01,F
032A D7F8           00872 BRA    031C
032C 6AEA           00873 CLRF   FEA
032E 6AE9           00874 CLRF   FE9
0330 50C1           00875 MOVF   FC1,W
0332 0BC0           00876 ANDLW  C0
0334 090F           00877 IORLW  0F
0336 6EC1           00878 MOVWF  FC1
0338 0E07           00879 MOVLW  07
033A 6EB4           00880 MOVWF  FB4
033C 50B4           00881 MOVF   FB4,W
033E 9CA1           00882 BCF    FA1.6
0340 86B8           00883 BSF    FB8.3
0342 0E35           00884 MOVLW  35
0344 6EAF           00885 MOVWF  FAF
0346 0E26           00886 MOVLW  26
0348 6EAC           00887 MOVWF  FAC
034A 0E90           00888 MOVLW  90
034C 6EAB           00889 MOVWF  FAB
034E 9494           00890 BCF    F94.2
0350 848B           00891 BSF    F8B.2
0000                00892 ....................    //
0000                00893 ....................    // Defino variables locales
0000                00894 ....................    //
0000                00895 ....................    int      iRet;
0000                00896 ....................    char   sBuffer[ MF_BUFFER_SIZE ];
0000                00897 ....................    char   sGetInfo[ 5 ] = { 0x16, 0x00, 0x4F, 0x00, 0x4F };
0352 0E16           00898 MOVLW  16
0354 6E27           00899 MOVWF  27
0356 6A28           00900 CLRF   28
0358 0E4F           00901 MOVLW  4F
035A 6E29           00902 MOVWF  29
035C 6A2A           00903 CLRF   2A
035E 6E2B           00904 MOVWF  2B
0000                00905 ....................
0000                00906 ....................
0000                00907 ....................    setup_adc_ports(NO_ANALOGS);
0360 50C1           00908 MOVF   FC1,W
0362 0BC0           00909 ANDLW  C0
0364 090F           00910 IORLW  0F
0366 6EC1           00911 MOVWF  FC1
0000                00912 ....................     setup_adc(ADC_OFF);
0368 90C2           00913 BCF    FC2.0
0000                00914 ....................    setup_ccp1(CCP_OFF);
036A 0EB7           00915 MOVLW  B7
036C 16B1           00916 ANDWF  FB1,F
036E 8494           00917 BSF    F94.2
0370 6ABD           00918 CLRF   FBD
0372 6ABD           00919 CLRF   FBD
0000                00920 ....................       setup_ccp2(CCP_OFF);
0374 16B1           00921 ANDWF  FB1,F
0376 8294           00922 BSF    F94.1
0378 6ABA           00923 CLRF   FBA
037A 6ABA           00924 CLRF   FBA
037C 6AB6           00925 CLRF   FB6
037E 6AB7           00926 CLRF   FB7
0000                00927 ....................       setup_comparator(NC_NC_NC_NC);
0380 0E07           00928 MOVLW  07
0382 6EB4           00929 MOVWF  FB4
0384 5092           00930 MOVF   F92,W
0386 0E14           00931 MOVLW  14
0388 6E00           00932 MOVWF  00
038A 2E00           00933 DECFSZ 00,F
038C D7FE           00934 BRA    038A
038E 0000           00935 NOP
0390 50B4           00936 MOVF   FB4,W
0392 9CA1           00937 BCF    FA1.6
0000                00938 ....................       setup_vref(FALSE);
0394 6AB5           00939 CLRF   FB5
0000                00940 ....................     setup_psp(PSP_DISABLED);
0396 9896           00941 BCF    F96.4
0000                00942 ....................     setup_spi(FALSE);
0398 9AC6           00943 BCF    FC6.5
039A 9A94           00944 BCF    F94.5
039C 8894           00945 BSF    F94.4
039E 9694           00946 BCF    F94.3
03A0 0E00           00947 MOVLW  00
03A2 6EC6           00948 MOVWF  FC6
03A4 6EC7           00949 MOVWF  FC7
0000                00950 ....................     setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
03A6 90D1           00951 BCF    FD1.0
03A8 0E80           00952 MOVLW  80
03AA 6ED5           00953 MOVWF  FD5
0000                00954 ....................    setup_timer_1(T1_DISABLED);
03AC 6ACD           00955 CLRF   FCD
0000                00956 ....................     setup_timer_2(T2_DISABLED,0,1);
03AE 0E00           00957 MOVLW  00
03B0 6ECA           00958 MOVWF  FCA
03B2 0E00           00959 MOVLW  00
03B4 6ECB           00960 MOVWF  FCB
0000                00961 ....................    disable_interrupts( GLOBAL );
03B6 9CF2           00962 BCF    FF2.6
03B8 9EF2           00963 BCF    FF2.7
03BA BEF2           00964 BTFSC  FF2.7
03BC D7FD           00965 BRA    03B8
0000                00966 ....................
0000                00967 ....................
0000                00968 ....................    MF_SendFrame( sGetInfo, 5 );
03BE 6A2D           00969 CLRF   2D
03C0 0E27           00970 MOVLW  27
03C2 6E2C           00971 MOVWF  2C
03C4 0E05           00972 MOVLW  05
03C6 6E2E           00973 MOVWF  2E
03C8 D725           00974 BRA    0214
0000                00975 ....................    iRet = MF_RecvFrame( sBuffer );
03CA 6A2D           00976 CLRF   2D
03CC 0E07           00977 MOVLW  07
03CE 6E2C           00978 MOVWF  2C
03D0 D76D           00979 BRA    02AC
03D2 C001 F006      00980 MOVFF  01,06
0000                00981 ....................
0000                00982 ....................
0000                00983 ....................    fprintf( SERIAL_2, "\n\r" );
03D6 0E0A           00984 MOVLW  0A
03D8 A89E           00985 BTFSS  F9E.4
03DA D7FE           00986 BRA    03D8
03DC 6EAD           00987 MOVWF  FAD
03DE 0E0D           00988 MOVLW  0D
03E0 A89E           00989 BTFSS  F9E.4
03E2 D7FE           00990 BRA    03E0
03E4 6EAD           00991 MOVWF  FAD
0000                00992 ....................
0000                00993 ....................
0000                00994 ....................    sleep();
03E6 0003           00995 SLEEP
0000                00996 .................... }
0000                00997 ....................
03E8 0003           0998 SLEEP
Configuration Fuses:
   Word  1: C200   HS IESO FCMEN
   Word  2: 1E1F   BROWNOUT NOWDT BORV21 NOPUT WDT32768
   Word  3: 8700   CCP2C1 PBADEN LPT1OSC MCLR
   Word  4: 0081   STVREN NODEBUG NOLVP NOXINST
   Word  5: C000   PROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
SYMBOL TABLE
  LABEL                             VALUE
_RETURN_                          00000001
main.iRet                         00000006
main.sBuffer                      00000007
main.sGetInfo                     00000027
MF_SendFrame.sData                0000002C
MF_RecvFrame.sData                0000002C
MF_RecvFrame.iLen                 0000002E
MF_SendFrame.iDataLen             0000002E
MF_Kbhit.lTimeOut                 0000002F
MF_SendFrame.iPtr                 0000002F
MF_Debug.siTXRX                   00000030
MF_Debug.sData                    00000031
MF_Debug.iDataLen                 00000033
MF_Debug.iPtr                     00000034
PSP_DATA                          00000F83
C1OUT                             00000FB4
C2OUT                             00000FB4
CCP_2_LOW                         00000FBB
CCP_2                             00000FBB
CCP_2_HIGH                        00000FBC
CCP_1_LOW                         00000FBE
CCP_1                             00000FBE
CCP_1_HIGH                        00000FBF
MF_Debug                          00000130
MF_Kbhit                          0000024E
MF_SendFrame                      00000214
MF_RecvFrame                      000002AC
main                              0000030A
MEMORY USAGE
cfernandez
MPASM
                         57 (1%) worst case
               Stack:    4 locations
01D0 0000           00575 NOP
01D2 0000           00576 NOP
01D4 0000           00577 NOP
01F8 0000           00593 NOP
01FA 0000           00594 NOP
01FC 0000           00595 NOP
029A 0000           00632 NOP
029C 0000           00633 NOP
038E 0000           00935 NOP
SYMBOL TABLE
  LABEL                             VALUE
_RETURN_                          00000001
main.iRet                         00000006
PSP_DATA                          00000F83
C1OUT                             00000FB4
C2OUT                             00000FB4
CCP_2_LOW                         00000FBB
CCP_2                             00000FBB
CCP_2_HIGH                        00000FBC
CCP_1_LOW                         00000FBE
CCP_1                             00000FBE
CCP_1_HIGH                        00000FBF
MF_Debug                          00000130
MF_Kbhit                          0000024E
main                              0000030A
MEMORY USAGE
cfernandez
PostPosted: Tue Feb 08, 2005 8:23 am     Reply with quote
#device *=16
#device adc=8
#case
#opt 11
#zero_ram
   int    iPtr;
   if ( siTXRX )
   int      iPtr;
   int      iLen = 0;
   return iLen;
   int      iRet;
    setup_adc(ADC_OFF);
      setup_vref(FALSE);
    setup_spi(FALSE);
   sleep();
