Float Precision
Kimi
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Float Precision
PostPosted: Fri Feb 04, 2005 11:54 am     Reply with quote
Hello
First of all, thanks very much to everybody... this forum is great...
Now let's go to the problem... I'not getting enough precision in floating points maths...
x1 = -34.61084;
f1 = 12.44 * x1;
after this we expected f1 = -430.5588496, but we watch f1 = -430.558830
this is just the begining...as we continue doing maths with this floats, errors become biggers...
f1 = f1 + 110574; //just adding a number
Expected f1 = 110143.4411504 -- calculated by Pic f1 = 110143.438726
Is there any way to double the Floating point precision? or at least increase it... Is this a compiler limitation, or a MCU limitation?
Thanks very very much
Kimi
Kimi
PostPosted: Fri Feb 04, 2005 12:31 pm     Reply with quote
I found that the printf is wrong...
dist1 = 110143.4411504;
fprintf (PC," %f ",dist1);
this should return 110143.4411504 but I see 110143.432021 in the PC.
anybody could solve this problem?
Kimi
Neutone
PostPosted: Fri Feb 04, 2005 1:14 pm     Reply with quote
The floating point format used by CCS has 6.5 significant digits. It's a 32 bit float not as much percision as used in most PC software.
Kimi
PostPosted: Fri Feb 04, 2005 1:44 pm     Reply with quote
Is there any usefull way to display the 4 bytes that compose the float into screen... first to check the operation, second to be able to send a float though the serial or spi port.
Kimi
SherpaDoug
PostPosted: Fri Feb 04, 2005 3:57 pm     Reply with quote
If you make a pointer to the float you can print the bytes in hex.
My advice is not to use floats unless you really REALLY have to. I measure temperature all the time in integer millidegrees. A while back I was measuring warping in ship hulls in 24bit integer 1/10 millimeters. I could measure everything from the thickness of the paint to the length of a supertanker. I used string functions to convert the results to meters for printing.
