PIC18 A/D q. select analog
Beginner
PostPosted: Thu Feb 03, 2005 2:05 pm     Reply with quote
I must use analog port in PIС18F4320 :
as PIN RA3-Vref+; RA4 - button; RA5 - analog in;
RA0,RA1,RA2-digital i/o ;
How I can do this?
If I can use analog port as
only: A0, or A0 and A1 or A0 and A1 and A2 //etc/
in header file.
PLEASE answ/ me!
PostPosted: Thu Feb 03, 2005 3:37 pm     Reply with quote
Read the data sheet for the chip.
You can only configure the port as the _hardware_ allows. What you describe cannot be done.
Beginner
PostPosted: Thu Feb 03, 2005 3:41 pm     Reply with quote
So If I use Vref , then I can't use RA0,RA1,RA2 as digital io?
Mark
PostPosted: Thu Feb 03, 2005 6:33 pm     Reply with quote
No, if AN0 is a digital i/o then you don't get any analog inputs. The analogs need to start at AN0 and go up.
Beginner
PostPosted: Fri Feb 04, 2005 11:14 am     Reply with quote
And about this:
I use PORTA0,1,2 as digital output and can use analog input(RA3 - Vref; RA5-input;) when digital don't use . So I must commutate from analog to digital.
This is too not correct????
Beginner
PostPosted: Fri Feb 04, 2005 11:17 am     Reply with quote
By communitate with function setup_adc_ports();?????
