Kimi
Bugs with Float? |
Posted: Thu Feb 03, 2005 1:56 pm |
Hello
I have a piece of code, which involves making very complex float maths. I have to calculate the distance from two near points which are given by a GPS. I have the formula to calculate this, but I have found a extrange behaviour when adding two floats values. This is the Piece of Code, and I will tell what the printf shows
#include <16F877.h>
#include <math.h>
#use delay(clock=16000000,RESTART_WDT)
#fuses NOWDT,HS, NOPUT, NOPROTECT, NOBROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#use rs232(baud=57600,parity=N,xmit=PIN_D2,rcv=PIN_D3,bits=8,stream=PC,errors)
float dist1;
float temp1;
void tracking (float lat1,lon1,lat,lon) {
dist1 = lat1;
dist1 = dist1 * 12.44;
dist1 = dist1 + 110574;
temp1 = lat1;
temp1 = temp1 - lat;
void main () {
float a1,a2,x1,x2;
a1 = -34.61084;
a2 = -58.43049;
x1 = -34.60900;
x2 = -58.42851;
tracking (a1,a2,x1,2);
fprintf(PC,"dist1: %4.4f temp1: %4.4f",dist1,temp1);
The printf shows dist1: 110143.4387 temp1: -166.6108
Shouldn't temp1 be: -0.00184?
Kimi |
C-H Wu Guest
float bug in function definition ? |
Posted: Thu Feb 03, 2005 8:41 pm |
Kimi:
I use PCWH 3.187, 3.212, 3.216, 3.218 to compile your code, bug confirmed for both F877 with PCM and 18F4620 with PCH!
Code: | 038-03B tracking.lat1 <-- float, 4 bytes
03C tracking.lon1 <-- become int8, only 1 byte ! bug ?
03D tracking.lat <-- become int8 ! bug ?
03E tracking.lon <-- become int8 ! bug ?
workaround :
void tracking (float lat1,float lon1,float lat,float lon) {
03C-03F tracking.lat1
040-043 tracking.lon1 <-- no more bug
044-047 tracking.lat
048-04B tracking.lon
However, there is no such bug with the following syntax
void main () {
float a1,a2,x1,x2;
I never notice this CCS feature , thanks a lot for your information.
You should file a bug report to CCS !
Best wishes
C-H Wu |
Posted: Thu Feb 03, 2005 9:24 pm |
It's a bug, but in the sense that the compiler should have given
an error, instead of defaulting to int8.
If I look in the help file for MSVC++ 6.0
and look under "Function Parameters", it says this:
Code: | Each identifier in parameter-type-list must be preceded by its appropriate type specifier, as shown in this example:
void new( double x, double y, double z )
/* Function body here */
CCS is based on K&R, and maybe somewhere in K&R it says the
same as above, but I'm not going to spend any more time looking for it. |
Mark
Posted: Thu Feb 03, 2005 10:10 pm |
Quote: |
In the ANSI standard:
Definitions must be coded in the same order in which arguments are passed.
Only one identifier for each type specifier can be coded in an ANSI
parameter definition.
The comma ( , ) now separates the definitions between the parentheses.
There is no semicolon to terminate a definition.
The default data type for CCS is int8 thus what you see. |
Posted: Thu Feb 03, 2005 10:49 pm |
The key part is here in these two sentences:
The comma ( , ) now separates the definitions between the parentheses. |
That means you can't do this:
Code: | void func(float a, b, c, d); |
You must do it this way:
Code: | void func(float a, float b, float c, float d); |
Because CCS doesn't give an error for the first declaration above,
it's in violation of the ANSI standard. But CCS doesn't say that
they are in accord with ANSI.
If I try to find some compiler on my system that might be K&R
compatible, I have Quick C for Windows vs. 1.0, copyright 1991.
If I run the following code,
Code: | void my_func(float a, b, c, d)
then I get this error message:
C:\QCWIN\GENERAL\TEST.C(6) : error C2061: syntax error : identifier 'b'
TEST.EXE - 1 error(s), 0 warning(s)
I have to do this to avoid an error:
Code: | void my_func(float a, float b, float c, float d)
So CCS is in violation of ANSI and probably K&R as well.
They shouldn't default to int8 for parameters that are missing a
type-definition. They should give an error. |
