Erik Guest
ICD-U and 12F675 |
Posted: Fri Apr 11, 2003 5:37 am |
...today my ICD-U unit arrived but unfortunately there comes no documentation with it:(
In the FAQ section it is described how to connect the ICD-U unit, next to MCLR, VDD, GND, B3, B6 and B7 are referred for connection.
Unfortunately on the 12Fxyz Port B doesnīt exit !
I guess that i will have to use the same pins as used for ICP and one Pin more for "advance debugging", but that doesnīt really help me....
Does anybody know how to connect the ICD-U to a 12F675 ?!?
thanks for all helpful postings !
___________________________
Original Post ID: 13604 |
john cutler
Joined: 06 Sep 2003 Posts: 82 Location: Hot Tub, California
Re: ICD-U and 12F675 |
Posted: Fri Apr 11, 2003 9:55 am |
:=Hello,
:=...today my ICD-U unit arrived but unfortunately there comes no documentation with it<img src="http://www.ccsinfo.com/pix/forum/sad.gif" border="0">
:=In the FAQ section it is described how to connect the ICD-U unit, next to MCLR, VDD, GND, B3, B6 and B7 are referred for connection.
:=Unfortunately on the 12Fxyz Port B doesnīt exit !
:=I guess that i will have to use the same pins as used for ICP and one Pin more for "advance debugging", but that doesnīt really help me....
:=Does anybody know how to connect the ICD-U to a 12F675 ?!?
:=thanks for all helpful postings !
The Microchip Data sheet for the 12F675...
Pin 4 (of PIC) /MCLR
Pin 6 ICSP Clk
Pin 7 ICSP Data
The other two are Vdd and Gnd
Have fun
Original Post ID: 13613 |
Erik Guest
Posted: Fri Apr 11, 2003 10:36 am |
..thanks, i know that already.
The Problem is i donīt know how to map the ICP Pins of the 12F675 with the B3, B6 and B7 ICU Pin. Furthermore there are 6 Pins (not 5 as used for ICP) used by the ICU, the 6th for "advanced debugging" - donīt aks me whatīs that for, i didnīt get so far...
Original Post ID: 13614 |
Posted: Fri Apr 11, 2003 11:23 am |
:=..thanks, i know that already.
:=The Problem is i donīt know how to map the ICP Pins of the 12F675 with the B3, B6 and B7 ICU Pin. Furthermore there are 6 Pins (not 5 as used for ICP) used by the ICU, the 6th for "advanced debugging" - donīt aks me whatīs that for, i didnīt get so far...
They refer to B6 and B7 because these are the pins used
by the 16F877 for ICD. I've modified the chart to
help you identify the proper pins on the 12F675:
<PRE>
12F675
pin # Signal name
4 /MCLR
6 ICSP Clk ("B6")
7 ICSP Data ("B7")
</PRE>
Original Post ID: 13616 |
Neutone
Posted: Fri Apr 11, 2003 11:32 am |
Refer to this sheet.
<a href="http://www.microchip.com/download/tools/picmicro/icds/mplabicd2/51265c.pdf" TARGET="_blank">http://www.microchip.com/download/tools/picmicro/icds/mplabicd2/51265c.pdf</a>
The headder is the same.
Original Post ID: 13617 |
Erik Guest
Posted: Sat Apr 12, 2003 4:58 am |
...wow, thanks for the quick help !
..according to the ICD2-documentation link which was posted, is the ICD-U compatible to microchips ICD2 (or ICD1) ? Can i use it also from MPLAB ?
Unfortunately i canīt find any documentation off the ICD-U on the ccs web-site...
Original Post ID: 13629 |
Posted: Sun Apr 13, 2003 1:25 pm |
:=...wow, thanks for the quick help !
:=..according to the ICD2-documentation link which was posted, is the ICD-U compatible to microchips ICD2 (or ICD1) ? Can i use it also from MPLAB ?
:=Unfortunately i canīt find any documentation off the ICD-U on the ccs web-site...
I don't own it, so I can't tell you any more than what I
read on the CCS website. <a href="http://www.ccsinfo.com/icds.html" TARGET="_blank">http://www.ccsinfo.com/icds.html</a>
You should email CCS support about your questions.
<a href="http://www.ccsinfo.com/techsupport.shtml" TARGET="_blank">http://www.ccsinfo.com/techsupport.shtml</a>
Original Post ID: 13638 |
