Can write_program_memory() change configuration bits?
Posted: Thu Feb 03, 2005 2:47 pm
I need to set the brown out detect configuration bit of some PICs (18LF452) in the field. Our firmware contains a bootloader, so I'm wondering if I can write a new mainline that simply changes the configuration bits. The changes will not need to take affect until the next time the PIC is restarted.
Rob
Posted: Thu Feb 03, 2005 3:39 pm
Yes it can.
This is the basis of the 'bootloader' type programs. Obviously assuming you don't have this area protected in any way.
