Saving floats to EEPROM?
Toups
PostPosted: Tue Feb 01, 2005 3:47 pm     Reply with quote
Hello all,
How can I save a floating point variable to internal EEPROM?
Lance
PostPosted: Tue Feb 01, 2005 4:04 pm     Reply with quote
Look in the CCS FAQ, at this question:
http://www.ccsinfo.com/faq/?24
Since you're writing to internal eeprom, just use "write_eeprom()"
and "read_eeprom()" instead of the external eeprom functions.
Also, because the address is only 8-bits for data eeprom, you can
change the parameter declarations from "long int" to "int8".
Toups
PostPosted: Tue Feb 01, 2005 4:11 pm     Reply with quote
I really apreciate the help. I need to look through
the FAQ's a bit closer.
